Members: 13,645 | Total Threads: 40,056 | Total Posts: 470,826 Currently Active Users: 767 (18 members and 749 guests) Welcome to our newest member, asouqihifu |
02-01-18, 10:13 PM | #21 | |
This stuff has been discussed at length on the Volvo Amazon forum I follow from time time. It's bl**dy expensive but seems to be the dog's for sorting out corrosion problems with electrical connectors causing voltage drops. |
02-01-18, 10:46 PM | #22 |
02-01-18, 11:16 PM | #23 |
I suspected something was up, good luck with selling it all. Typo, you'll have no trouble selling the UR Quattro you just got started.
03-01-18, 09:05 PM | #24 | |
http://www.urquattro.info/ "1985 wiring diagrams in English" Near the bottom of the main page. Beware Bentley manuals are US spec cars. |
03-01-18, 09:07 PM | #25 |
You will get a kick out of this, had the car running for a good 20 minuets today, refilled radiator with coolant, stat opened up and ran Ok but above 1100rpm, so was messing about with that to get the rpm down and the 3mm allen key mixture screw and the car just died, so where do you start, turn the idle screw back up and un-turn the 3mm allen key mixture screw,
but the bugger won't fire up, make sure you have a spark, spark is ok, then the penny dropped, run out of fuel, well that should be an easy fix , maybe tomorrow. |
03-01-18, 09:10 PM | #26 | |
03-01-18, 10:13 PM | #27 |
