Members: 13,710 | Total Threads: 40,056 | Total Posts: 470,826 Currently Active Users: 695 (20 members and 675 guests) Welcome to our newest member, tadalafil 20 mg |
23-02-20, 05:14 PM | #1 | |
new power going too fuel pump
right here gos hoping for sum help here please,,my audi 90 1985 has no power going too the pump. ave checked fuse under back seat its good, did a wee check with wire from battrie too rear seat and pump works,,so sum1 told me too take out relay and short two numbers out wich i did and pump worked fuses are good too so any suggestions welcome am a bit stuck now
23-02-20, 05:38 PM | #2 |
Have you tested the relay ?
You've already verified the pump is ok. Shorting the 2 pins should be equivalent of the relay working. So your circuit is good. You've not got much left. Either the relay is not operating or it's not getting the signal to operate.
23-02-20, 05:43 PM | #3 |
hi i bought a new relay but whos not too say its not working
where does signal come from ? |
23-02-20, 05:59 PM | #4 |
23-02-20, 10:30 PM | #5 |
ok thanks guys will have a look after work tomo thanks
29-02-20, 09:00 PM | #6 |
29-02-20, 09:28 PM | #7 |
Your relay will have 7 pins yes.
Checking the wiring is required, Haynes manual to hand??!! |
06-03-20, 10:35 PM | #8 |
took relay off today and took it too a local lad who has a 2.0 coupe .we put my relay in and car wouldnt start so my relay is goosed managed too source another one in my loft and cars alive again happy days 1 job off the long list of resto thanks for all who commented
