Members: 13,689 | Total Threads: 40,056 | Total Posts: 470,826 Currently Active Users: 784 (18 members and 766 guests) Welcome to our newest member, amacdonea |
20-07-16, 07:38 AM | #1 | |
Oil warning light
On my 2.3 B3 Coupe the Oil Warning light and sound has started coming on but only when I pull up to a stop. To me this suggests possibly when the car drops to idle the oil pressure is dipping below optimum and its sending the alarm off? The Oil pressure seems to run from one scale to the other, while running its right at the top, full on 5 bar then when you pull up it goes down to one bar. As someone not especially mechanical I would have said that was fairly normal but open to opinions.
The oil level is fine and oil looks clean. I am going to get the oil changed today anyway just in case but I dont think its as simple as that. |
20-07-16, 07:56 AM | #2 |
Have heard scare stories about pick-up strainer pipes becoming blocked but I think you're doing the right thing in getting the oil changed, and take it from there.
20-07-16, 08:01 AM | #3 |
Do you mean the oil warning light on the instrument panel Crossle?...
looks like an oil can? if yes, it's the oil pressure warning lamp and not a monitor for the oil level. Should come on when engine is switched on and go out after engine is started. Manual states: if it doesnt go out or if it comes on whilst driving (buzzer will sound above 2000rpm), switch off engine immediately, and if oil level is good, dont drive the vehicle or continue to run the engine, even at idle speed. From what you've described, sounds like a fault somewhere, a sensor maybe? might be worth getting a diagnostic report to see what faults do show up. |
20-07-16, 08:04 AM | #4 | |
20-07-16, 08:20 AM | #5 |
Its not the lights that come on with the ignition know (not in the cluster of different square lights in the centre of the instrument panel). This is the big square box at the top of the instrument panel which is a digital read out and can show a multitude of different messages. I am not in a panic over it (well not at the moment anyway!!) as the engine sounds very sweet, there is good oil pressure under load and there is no oil warnings under load. Its only when you pull up it quickly lights up, sends a warning tone and then goes off again.
20-07-16, 08:31 AM | #6 |
Blimey, your very close to me then, I'm in Roade village. Thanks for the offer mate but I've got all the information, I just like being lazy and asking the experts on here!
20-07-16, 08:34 AM | #7 |
20-07-16, 08:41 AM | #8 |
Thanks Lee, appreciated. I will probably spot you out and about!
The clothing you were asking about by the way is available to order here- http://www.firstavenuesupplies.co.uk...ry&path=60_109 |
20-07-16, 07:28 PM | #9 |
1 bar on tickover doesn't sound right, when you first start the car from cold the pressure should be 5 bar, then as the oil warms up and becomes more fluid it should go down to 3 bar, this is when just left ticking over not driving, both my Coupes show 5 bar under load as in driving and only drop to 3 bar when stopped at lights etc. At 1 bar i think the oil pressure is too low, then again maybe i am in trouble
20-07-16, 08:39 PM | #10 | |
