Classic Audi Classifieds section Parts Wanted » Audi 90 20v (7A) Fuel Pump
Old 02-01-22, 02:36 PM   #1
Obli
Default Audi 90 20v (7A) Fuel Pump
Hi folks,
I'm trying to get my old 1991 90 20v started after some years of being sat around under cover. I'm looking for a fuel pump, new or second hand, suitable to fit. Looked up the part number, believed to be 893 906 091B (or E? Not sure of the suffix difference),
Had a look on eBay. Not sure if a new, cheap one is even worth a punt...
Is anyone able to help, please? Thanks for your time,
James
Obli is offline   Reply With Quote
Old 02-01-22, 06:16 PM   #2
I've got one like this on my 2.6 90
https://www.fuelpumpsonline.co.uk/in...10-23395-p.asp
1988 90 quattro 2.6 TSR
1991 90 quattro
Old 03-01-22, 10:21 AM   #3
Obli
Thank you mikes2, for the recommendation and link - good to know.
I've had a hunt around myself. Found the following Magneti Marelli fuel pump.
https://m.buycarparts.co.uk/magneti-marelli/7613355
Reg check for my 90 20v states not compatible but OEM numbers match and car fitment looks right (not sure what the 8A is though). Has anyone used this particular pump?
EDIT: The pump recommended by Magneti Marelli in their catalogue is a different part number.
ESS0112A, 219900000112
https://m.buycarparts.co.uk/magneti-marelli/7613406
Looks like it has the right terminals to screw on, different to the other one which probably works but would require modification.
Best wishes,
James
Old 03-01-22, 05:02 PM   #4
893 906 091 B for a 20v fwd, 893 906 091 E if it's quattro 20v
1991 90 quattro
Old 03-01-22, 08:15 PM   #5
slacky
slacky's Avatar
What would the differences be Mike ?
90q-Cab.
2.3E-Ur-S6
-b2-80 Sport
Member 111
Old 03-01-22, 09:03 PM   #6
usually the inlet diameter is different.
1991 90 quattro
Old 04-01-22, 08:53 PM   #7
slacky
slacky's Avatar
Thanks
90q-Cab.
2.3E-Ur-S6
-b2-80 Sport
Member 111
Copyright ©2000 - 2022, Jelsoft Enterprises Ltd.
