Classic Audi » Technical » Mech/Tech » Engine » Treser UR rough running
Old 03-04-21, 08:43 PM   #1
Treser UR
Default Treser UR rough running
Can you guys offer any reasons for jerky handling on my WR.Acceleration and deceleration is fine but in traffic or just maintaining any constant speed it’s not happy and hunts all the time.Maybe a fuel/air mix problem? What other possibilities are there from you wise guys?
Thanks
Treser UR is offline   Reply With Quote
Old 04-04-21, 01:49 AM   #2
Hanuman
Hanuman's Avatar
Is his sudden, or gradual?
This sort of thing plagued my WR for a while until I got a grip with keeping it fettled, and it wasn’t anything major as such.
First few things worth checking, before getting into the more technical stuff.
Induction system- no air leaks. One of the most common causes of poor tune being the mixture at idle adjusted to compensate for an air leak. The engine should stall if the oil cap is removed. If it doesn’t, and some don’t even stumble when the cap is removed, then there is unmetered air being overcompensated for,
The various small bore vacuum hoses around the system need to be in good shape.
The idle screw needs to have a good o-ring seal, and the throttle body needs to be clean. The induction system does build up oil residue over time, which messes with the idle bleed.
Fuel system- pump delivery, mainly.
But also worth establishing that the cold start injector isn’t feeding extra fuel.
The above being for a standard WR. On the tresser, I’ve little idea what else goes on.
enjoying Fish amok and a draught Angkor
Old 04-04-21, 07:57 AM   #3
Treser UR
Thanks for your views which seem very sensible.Curious to know what action cured your problem.The cold start injector was replaced recently and whilst it starts first time now,at lease when it’s a cold start,maybe it throws in fuel when it warms up.Is that a sensor issue?
The jerkyness starts from start up and when it’s warmed up it still does it.Slow traffic travel involves a lot of clutch work so it doesn’t kangaroo so a right pain.
The Treser has Mercedes v8 fuel distributor,a higher lift cam and bigger valves and bigger inter cooler but otherwise the set up is as standard.
Could the problem be an injector seal or a stuck injector that sprays inconsistently?
Thanks
Old 04-04-21, 08:24 AM   #4
In the UK you’ll find a significant number of Urs (especially as they’re not used as a daily/winter car now) have the cold start injector disconnected as it hampers warm starts with flooding.
That said, I’d go with Mark and the induction system, they’re pretty sensitive. Try the ‘stumble’ test.
Also, have a quick check of the wiring to the air flow sensor on the front of the inlet manifold.
Old 05-04-21, 01:53 PM   #5
Hanuman
Hanuman's Avatar
Originally Posted by Hanuman View Post
Is this sudden, or gradual?
I may have been a little unclear. Did this situation develop very quickly, 1-2 days, or something that became gradually worse over a longer period?
In any event, I’d suggest all those things that I mentioned should be checked first. I would say that the biggest and lasting improvement that I had was ensuring that the system had no air leaks, idle screw and port were clean (it does gunk up to the point that you run out of idle adjustment completely.) and then mixture set right.
Old 06-04-21, 06:53 PM   #6
Treser UR
Thanks for that.It’s been occurring for a while but haven’t been using the car much during the winter months so haven’t done anything about it.
Now the sun is out it needs fixing.
Old 07-04-21, 03:48 PM   #7
Hanuman
Hanuman's Avatar
As it’s something that’s developed over time, it doesn’t sound like anything has broken completely, suddenly. So I’m inclined to think it’s a slow degradation, that has been compensated for over time. But now has reached the point that it needs sorting. As such, I’d go with the basics, making sure those are right.
Old 11-04-21, 12:50 PM   #8
larry49
Hunting is a sign of fuel/mixture problems....If it were mine I would do a complete fuel pressure test, check the AFM flap for smooth operation, check injector flow and the main fuel plunger in the distributor....(handle it with care).
larry49 is offline   Reply With Quote
