Members: 13,639 | Total Threads: 40,056 | Total Posts: 470,826 Currently Active Users: 771 (16 members and 755 guests) Welcome to our newest member, uyowabexugem |
07-02-16, 07:21 PM | #1 | |
digital dash problem
hi guys having digital dash problem. lights gone very dim still operating all functions just can hardly see them. for some reason lights go back to normal when turning ignition off but only for a second tho. can anyone give me peter knights details as can't find them anywhere but sounds like he's the man for the job? many thanks mark
07-02-16, 09:14 PM | #2 |
You haven't inadvertently turned the dimmer switch by any chance?
07-02-16, 09:43 PM | #3 |
Pete Knight
07801624153 |
07-02-16, 10:35 PM | #4 |
digi dash
cheers phil for number much appreciated its mark with the black ur was at haigh hall sorry never got to chat much but enjoyed the show. cheers anth but unfortunately not so simple as dimmer wish it was tho
27-02-16, 11:50 AM | #5 |
Hi
Did you get hold of Pete Knight? Is he interested in fixing it? I have similar woe |
27-02-16, 07:38 PM | #6 |
Mr Sixty Thousand!!
If you get a full display at some points, it sounds like it could be related to your ignition switch, I had a similar thing several years ago, a slight backward turn of the key got the dash to light, a new switch sorted it completely. Only other common being the load relief relay does cut power to the dash when starting, if it plays up, no dash, although normally other electrical bits don't work.
http://www.oesems.co.uk/ |
28-02-16, 08:38 AM | #7 |
Thanks Darren. Interesting. I'll look at the switch/relay.
My dash was ok for a bit following a load of recommissioning work to the car ..and never had historical problems. It then had a period of being fine for two mins after startup and, thereafter, consistently showing erratic values for everything. Then she died. I was assuming the power inverter pack but have yet to remove it all from the car. Spring job. Is the dash load relief relay part of the dash or in the main fuse box? Ta |
