Classic Audi Technical Mech/Tech Engine » 7A replacement bosch injectors discussion
Old 11-03-19, 12:44 PM   #21
PoloGaz
PoloGaz's Avatar
So would you say I’m better sticking with the pinks? Were they too rich all the time or just on full load?
PoloGaz is offline   Reply With Quote
Old 11-03-19, 09:44 PM   #22
Don't think you'll see any benefit flowing more unless you plan to make other changes
1993 S2 estate
Old 11-03-19, 11:03 PM   #23
PoloGaz
PoloGaz's Avatar
Do you have any suggestions? Its cammed but running stock ECU map. Free flow exhaust...
Old 13-03-19, 11:01 AM   #24
Think there's a mod you can do using the 2.8 maf. Don't know much about it. Other than that you're looking at more capacity or turbo.
1993 S2 estate
Old 13-03-19, 09:47 PM   #25
20vcqdriver
20vcqdriver's Avatar
I had 190bhp with my 7A and around 180Lb/ft before going 20vt, had the larger V6 MAF the grey injectors adjustable FPR, standard cams and the Patrick Carlier re-map. Still all happenned after 4k which is why I moved to the 20Vt but it sounded awesome
Coupe quattro 1986:-~400bhp + loooong list of mods!
Audi A5 sportback 3.0TDI SLine quattro 2011
Audi A4 2.5TDi Sport cabriolet (163bhp) 2004:- Remapped to 180bhp
Old 14-03-19, 05:23 AM   #26
. the larger V6 MAF
Is it a straight swap?....or do you need the airbox as well, pipes changed, wiring plug??
Old 14-03-19, 11:03 AM   #27
20vcqdriver
Will try and dig out the Audi driver article I did on it but think it needs a remap to work properly and the right version of the MAF so its a plug in replacement.. Send email address via PM and will send article... if I can locate it
Old 14-03-19, 06:50 PM   #28
...but think it needs a remap to work properly
I too have a Patrick chip'd ECU.....I wonder if it just needs the MAF to finish it off?!
Old 17-03-19, 08:23 AM   #29
20vcqdriver
Patrick further modified mine to take into account the MAF signal change (larger bore MAF slower airflow speed for same rpm ) Have to ask him if he can still do this
Old 17-03-19, 10:19 AM   #30
I think I'll just leave it for now Dave, the car's not getting much use at the minute anyway. Food for thought though.
