Classic Audi Technical Mech/Tech Bodywork, glass & exterior fitments » b4 80 door mirror glass
Old 10-08-19, 10:53 AM   #1
sjp001
Default b4 80 door mirror glass
Hi all, A branch fell and broke the driver's side door mirror glass on my b4 80 avant last night. They are electric adjust and heated.
I thought I'd see if anyone has removed the glass before and might be so kind as to give me some advice... will some gentle prying with a screwdriver from the sides get the glass out, or am I going to snap a load of vital clips if I do this?
Thanks guys!
sjp001 is offline   Reply With Quote
Old 10-08-19, 02:30 PM   #2
it should pull off with some persuasion.
Plastic trim tools are ideal for this job. Trick is to adjust the glass all the way to one side to leave a gap.
If you have the replacement glass, you'll see how it's attached. Should be an extra connector for the heater element that just disconnects
1988 90 quattro project
Old 10-08-19, 04:50 PM   #3
sjp001
Thanks so much for that Mike, super helpful! Ordered a new glass so will give it a try when it arrives.
Old 15-08-19, 10:26 PM   #4
sjp001
Reporting back, mirror changed successfully without any breakages thanks to your great advice Mike! Many thanks!
Also turned out to be a nice upgrade because the driver side mirror used to be a magnified type which meant narrow field of view / big blind spot, etc. The new one has a substantially better field of view - not bad for 4 posted!
