Classic Audi Technical Mech/Tech Electrical problems » Where does this connector go??!! MB Quattro
Old 07-08-19, 02:18 PM   #1
oliverjl
Default Where does this connector go??!! MB Quattro
Is there anyone who knows where this wire should go to on my MB Quattro?? It is running from the loom just below the injector fan and seems to be homeless after having the engine out....
According to the colour my guess is the oil pressure switch (and the oil light wont go out on the dash making me more suspicious...), but the oil pressure switch seems to have a red connector on the bulkhead next to the master cylinder. Any help greatly appreciated...
oliverjl is offline   Reply With Quote
Old 07-08-19, 02:54 PM   #2
AdrianH
I haven't got my MB to hand just at the mo or I'd check. IIRC there are two thermo switches in the cylinder head near there *could it be one of those? (TBH I'd fire up Google translate and get going on the late Phil P's MB wiring diagrams.)
Old 07-08-19, 06:47 PM   #3
the round oil pressure sender on the side of the block only uses one of the connections (G) since there's no oil pressure gauge in the car.
1988 90 quattro project
Old 07-08-19, 08:28 PM   #4
oliverjl
Thanks very much, I will try that, but if thats the case it means I have 2 other wires spare....!!
Old 09-08-19, 04:07 PM   #5
oliverjl
Swapping the wire has cured the oil light, but I now have these 2 spare... blue/black and white/brown, they split off the loom below the distributor but are fairly long so could go anywhere!
Old 09-08-19, 04:41 PM   #6
SwallownAmazon
SwallownAmazon's Avatar
Wild guess - diagnostics connectors? Mine were hanging down from behind the dash after all the re-commissioning work on my B3 90 20v a couple of years ago. I recall they are the same colours.
Old 09-08-19, 06:44 PM   #7
Pretty sure they're for the 2 temp senders Adrian mentioned.
They're next to the power steering pump
Old 20-08-19, 11:39 AM   #8
oliverjl
Im still not getting very far with these wires... is there any chance someone with an MB Quattro could look what colours the wires are that go to the 2 temp sensors next to the power steering pump? It seems a bit strange that these would go there as they have the shrouds on the wires? Ive got photos before I dismantled it but I just cant make out the wire colours.
Thank in advance.
Old 20-08-19, 11:46 AM   #9
AdrianH
I'll take a look at mine this evening
