Classic Audi Technical Mech/Tech Electrical problems » Coupe/NG Temp sender
Old 21-07-18, 08:09 PM   #11
moonwatcher
moonwatcher's Avatar
Cheers guys,
Found the sensor, it was connected, cleaned it up, but still doesn't work!
Oh well, back to the drawing board.
Coupe Quattro 1985
Old 22-07-18, 05:33 AM   #12
Originally Posted by moonwatcher View Post
Cheers guys,
Single wire so will be NTC type, just short out the wire to see if the gauge goes up. If yes the sender's knackered, otherwise problem is elsewhere.
Old 23-07-18, 09:20 AM   #13
moonwatcher
John
Thank you very much for answering my next question, before I asked it
Coupe Quattro 1985
Old 23-07-18, 12:02 PM   #14
pretty sure there is a connector behind the driver side headlight for this wire which sometimes gives a bad connection
1993 S2 estate
Old 23-07-18, 02:51 PM   #15
Duffy3074
I thought it as just a single wire that went along the sump back towards the starter wiring Mike?
Old 24-07-18, 08:13 AM   #16
It goes into that loom yes.
I know my quattro had problems with a connection behind that headlamp for the oil temp sender. It's possible the cq doesn't have that same setup
1993 S2 estate
