Members: 13,480 | Total Threads: 40,056 | Total Posts: 470,823 Currently Active Users: 559 (10 members and 549 guests) Welcome to our newest member, rawapiceve |
19-11-12, 11:35 PM | #1 | |
Assorted parts for typ44 Avant QT & B2 Coupe
Evening folks; I'm hoping some of you kind-hearted hoarders may be able to help me ...
Firstly the parts for my typ44. I think she was feeling neglected and decided to demand some attention, and now she's in bits in the driveway again! Anyway, the list:
And onto the B2 Coupe parts ... and parts for the KG engine that's going into it
That's about all I can think of for now, but i'm sure i'll need a few more obscure bits before i'm done (the fusebox connector is the one that's holding me up at the mo). Anyway if you can help drop me a pm and i'll get back to you. Many thanks in advance folks |
20-11-12, 08:45 PM | #2 |
Hi, I can take a pair of snips to my spares car if you want for the electrical bits. I'll see if I have a switch that works, although I have swapped a good few out over the years for MOTs etc. I might have one that works! Some of the switches are the same underneath, they just have a different cover on them.
How much wire do you want on the connectors?? Which wires/colours? I haven't delved into the back side of one of these fuseboxes yet. For studs, nuts and washers I went to Audi and VAG specialists, not cheap but if you use the wrong ones it'll be coming off again in no time! Maybe quattro corner will have them. I've only got two sunvisor clips that work so I'll have to keep them I'm afraid, they seem to melt in the sun! Mastic will do the heater box, I didn't bother, it only leaks if you spray a hose in between the two bulkheads if the big plastic cover is in one piece. Which I have done once or twice. Just make sure the drain holes in there are clear. It'll be the weekend before I can get to it though, unless I learn to see in the dark in the meantime. |
20-11-12, 09:07 PM | #3 | |
John. |
21-11-12, 07:26 PM | #4 | |||||
Thanks for the response guys
