Members: 13,597 | Total Threads: 40,056 | Total Posts: 470,826 Currently Active Users: 833 (19 members and 814 guests) Welcome to our newest member, exaneqapequ |
05-11-18, 07:21 PM | #11 |
J
What car have you got? Model year etc On the vw heritage site you have to look at golf stuff or know what size pipe you have and then ring them. It sounds to me like the pipe is too big What id pipe are you using? The o rings on the link I did were called double ear clamps and o clips. Good place to start searching. Pirtek will have all of that. Take your original pipe along with the old filter and the new filter.... |
05-11-18, 08:35 PM | #12 |
Found a pic...
Top is feed, Bottom is return. Middle is speedo. Petrol pipe to the right is the braided sourced from heritage. You can just see the blue barbed reducer on hte feed pipe join. |
06-11-18, 09:07 AM | #13 |
I have used 8mm "microbore" copper central heating pipe in the past with great success.
Yes it is a bit of a pain to fit, but with care and attention you can put all the required bends in it to follow the course of the old pipes. You can also flare the ends, like brake pipes so that by using decent clamps the rubber hoses don't pop off. |
06-11-18, 06:49 PM | #14 | |
06-11-18, 06:55 PM | #15 | |
And i am referring to the fuel filter at the rear / under the car / on the drivers side. Just incase i didn't make this clear in my earlier posts. I have noticed that parts do fall under shared parts with the Mk1 Golf with the same engine. ie Mk1 GTI 1.8 8v So how do double ear clamps secure the pipe any better than a standard hose clamp? What am i missing? |
06-11-18, 06:59 PM | #16 | |
Now the top pipe with the blue join is the pipe work I find at the rear of the car, original fuel pipe & heat treated to fit at the factory(i believe). This is the pipe work I am struggling to find and replace sucessfully. |
06-11-18, 07:26 PM | #17 |
I am away from my car at the moment, but I have found an image online and it shows the plastic pipe I managed to cut..
The pipe runs from the back of the fuel filter to probably the accumulator, both ends are barb fittings requiring you to push on the pipe & then secure the a clamp around the ends of the pipe. This is where i am struggling, thank you in advance & sorry for multiple posts. Currently in Munich on bar wifi trying to figure out what i need and what i need to do when i get back in the UK and work on my car. Last edited by jampublic; 06-11-18 at 07:32 PM. |
06-11-18, 10:19 PM | #18 |
I now see why you are struggling. That is a factory crimped part. You could recreate it but not with jubilee clips!!! I suspect the O clips I mentioned will not cut the mustard either.
I think the the pipe you are after is 16 in the diagram below https://audi.7zap.com/en/rdw/audi+80.../201-36000/#16 Part number 811 201 218 B which is NLA. Last used in 87 according to ETKA. Nothing on german ebay/google under that part number. Looks like vw parts are different as the fuel tank is positioned differently. Closest is the Scirrocco. There are more than a few breaking the cars and by the looks it is fitted to all the 4 cylinder injection engines of that era. Try a request on the classic audi facebook page. If you want original/NOS give quattro corner a ring. They might be able to dig something up. Otherwise When you get home take off the accumulator and filter and take them with pipe ends/fittings you have to someone like Pirtek. Make sure to tell them its high pressure. I suspect that will the cheapest fastest way to get the job done. The have the tools to recreate those crimps properly. I waffle on...hopefully its useful and not telling you what you already know. |
07-11-18, 09:03 AM | #19 | |
https://www.viperperformance.co.uk/4...uel-hoses.html
08-11-18, 08:10 PM | #20 | ||
As for waffle, I am the one hijacking this thread & waffling! |
