Members: 13,700 | Total Threads: 40,056 | Total Posts: 470,826 Currently Active Users: 770 (21 members and 749 guests) Welcome to our newest member, aepudin |
20-01-08, 06:09 PM | #1 | |
A80 (1983) Master Cylinder ?
I've been ill since before Christmas so haven't had a chance to do anything to the cars. Just checked the timing belt on the Audi today and it's ok for now. Took it out this afternoon and remembered how much fun they are to drive. The brake pedal sinks if pressure is held on it for more than a few seconds (not all the way to the floor). It stops the car ok, the servo is working fine, but I suspect it might need a master cylinder. Are they still available, or does anyone know if any others (Golf ?) might be compatible ? Can you get seal kits for them ? |
21-01-08, 10:22 AM | #2 |
Mr Typ 43!
If it's the master cylinder I think it is then eBay had a genuine one last week for £10 - I nearly bought it! Ebay is probably your best bet - I got a new one for 99p! It wasn't the right one for my car but was an Audi one - it fitted and works fine, just had to bend the pipes slightly.
http://cgi.ebay.co.uk/New-Lockheed-B...QQcmdZViewItem |
21-01-08, 11:28 AM | #3 | |
Much appreciated. |
21-01-08, 11:54 AM | #4 |
Mr Typ 43!
I know it's a bit late but did you check it is compatible with your car? It should be okay but the one you bought may have a pressure switch for the brake light (which can be left unconnected if your car doesn't have one - generally used on earlier models). The other thing is that the brake resevoir on your 80 may have smaller lugs (bits which press into the master cylinder - the older resevoirs have larger lugs), I do happen to have a spare if you get stuck!
23-01-08, 03:38 PM | #5 | |
I changed the brush pack / voltage regulator but it hasn't cured the slightly glowing alternator light problem. Think a trip to the reconditioners is in order. Did someone on here say to check the engine earth strap ? I had a quick look for it today and didn't see one. I'll put a jump lead from the body to the block and see if it tells me anything. |
Similar Threads | ||||
Ebay ATE-Clutch-Master-Cylinder-To-Fit-Audi-100-200-Quattro | BIGGYIN | Parts For Sale | 0 | 26-11-09 08:01 PM |
wrong master cylinder? | andy | Suspension & Brakes | 8 | 28-10-09 08:24 PM |
master cylinder | andy | Suspension & Brakes | 1 | 20-10-09 09:26 PM |
Audi 80 B2 1985 brake master cylinder | Octanejunkie | Parts Wanted | 2 | 29-07-08 08:22 AM |
Master cylinder, no pressure? | Octanejunkie | Suspension & Brakes | 1 | 17-06-08 12:43 PM |
