Classic Audi » Technical » Mech/Tech » Engine » Injector removal
Old 15-04-13, 04:03 PM   #41
slacky
slacky's Avatar
Is this worth a try ??
http://forums.vwvortex.com/showthrea...Tool!!!-Custom!!!
90q-Cab.
2.3E-Ur-S6
-b2-80 Sport
Member 111
Old 26-04-13, 08:32 AM   #42
MSL
Injectors are back from the cleaners, new seals, new inlet gasket, all ready to go back on the car this weekend. Any top tips for re installing them?
MSL is offline   Reply With Quote
Old 05-03-14, 09:45 PM   #43
What parts,did you renew and where did you get them from?
KARL.
Old 06-03-14, 09:15 AM   #44
MSL
I got the seals from the company that cleaned the injectors and needed to replace a couple of the brown shrouds that came from Quattro corner I think.
They went back in a whole lot easier than they came out.....
Old 06-03-14, 07:17 PM   #45
Thumbs up Thanks.
Off the top of your head,do you remember if any of the parts were brass or copper?
Do the injectors just slide in,the brown plastic inserts?
KARL.
Old 06-03-14, 08:52 PM   #46
quattrostyle
Yes they pop in with the bigger green O-rings.
Old 06-03-14, 09:13 PM   #47
Thumbs up Thanks.
Might have found a supplier,in the UK?(A VW,site)
I will give you detail,when they reply to my email.
I take it the KV engine,doesn't use the brass upper insert?
KARL.
Old 07-03-14, 07:43 AM   #48
Did you have any problems,removing the old plastic inserts?How do you,remove them?
KARL.
Old 07-03-14, 07:02 PM   #49
Has anybody else,got any info please?
KARL.
Old 07-03-14, 07:09 PM   #50
Eddy
Eddy's Avatar
so to be clear,
once the injector is removed you will see a brass insert in the cylinder head, this is removed with a large allan key or drain plug key, it a fine thread and usually quite stiff to move, once this is removed the brown plastic insert is underneath. they should lift straight out but be very careful as they go very brittle over time, I would remove the inlet manifold and stuff a rag in the inlet so if you break them the wee bits don't go in to the engine.
parts are the same as the mk1 mk2 golf gti 1.8
