Classic Audi » Technical » Mech/Tech » Engine » Wanted: N75 Boost Control Valve etc
Old 21-06-14, 11:13 PM   #31
Andy10v
Andy10v's Avatar
erm . . .
funny you should say that as i noticed what we used to call in the old ford days, "pinking" when i gave it full boot . . .
does it really make a huge difference? checked the s6 handbook and right enough, it does say to use the high octane stuff . .
Yes it makes a difference. The ecu has knock detection, so you can run both, but with a power loss on lower octane. When the ecu detects detonation it will pull timing/boost (another reason you dont want a bleed valve as then ecu cannot lower boost, only pull timing when it detects knock).
You also notice the difference if you get a batch of bad fuel, depending on how the fuels octane has been raised (e85 or octane boosters?) it can go off, so some sites are better than others depending on turnover.
2005 350z GT
Sold-1993 ABY coupe
Old 21-06-14, 11:27 PM   #32
ok, that's a lesson! i'll give it the fancy stuff next time and see how it performs. i had a look through that fault list on the smjautotechnik but it's gobbledegook to me i'm afraid - i wouldn't have a clue where to start!
Old 21-06-14, 11:31 PM   #33
Andy10v
Andy10v's Avatar
What are your plans for it? Run as is or get it chipped?
2005 350z GT
Sold-1993 ABY coupe
Old 21-06-14, 11:47 PM   #34
i want to get it running properly as standard, andy and then i'll think about taking it further from there.
do you know of anyone up here who really knows these engines and who could set it up properly for me?
Old 22-06-14, 08:44 PM   #35
Andy10v
Andy10v's Avatar
Sounds like a sensible plan.
No recommendations I am afraid, I fix everything myself, then you know its been done
2005 350z GT
Sold-1993 ABY coupe
Old 22-06-14, 10:48 PM   #36
Error404
Thobbing Member
Error404's Avatar
Likewise.
Unless you have super deep pockets, you need to start learning about your car
With the 20vt I'd be super surprised if you can't find all the help you need on S2forum
Error404 is offline   Reply With Quote
Old 23-06-14, 08:21 AM   #37
Originally Posted by Error404 View Post
Likewise.
yup, they are a great bunch there too . .
Old 23-06-14, 08:22 AM   #38
andy, would you fancy taking a look at this old tub the next time i'm heading to perth to see the family?? you could always take it for a spin and let me know if you think it's down on power etc.
Old 23-06-14, 09:39 PM   #39
Andy10v
Andy10v's Avatar
I am quite happy to do a boost leak test and give it a look over, just drop me a PM.
We can leak test, clear codes, take it for a run and check for any codes again.
2005 350z GT
Sold-1993 ABY coupe
Old 24-06-14, 10:14 AM   #40
that's terrific, andy - i'll give you a shout next time i'm up that way.
thanks!
