Members: 19,823 | Total Threads: 40,095 | Total Posts: 471,121 Currently Active Users: 4051 (0 members and 4051 guests) Welcome to our newest member, BuddyInons |
#31 |
The other cable is for the light in the dash display.
It can only be the sender unit now, you've eliminated the gauge/wire must be the sender. |
#32 |
Thanks for quick reply.
To date, no one has mentioned having a Sender for sale. Have I got to buy a new one or is it worth starting a fresh thread for one? Oh, I may have explained it badly or am being thick, but I don't understand why the other cable on the Sender is for a dash light As always, thanks for all the help. Keith |
#33 |
Autocheck oil pressure warning is the other wire.
BMWs in scrap yards give up the senders too ![]() |
#34 | |
Pressure gauge, when not connected, goes up until max like yours does, and temp gauge doesn't moves. The same result for pressure gauge can be achieved if it's connected to incorrect pin on sender. |
#35 |
#36 | |
Losing me a little regarding Temp Gauge as the wiring diagram seems to show it entirely separate from Pressure Gauge with its own sensor. What do you suggest I try before purchasing Sender? Many thanks |
#37 |
Actually it's a bit hard to understand your situation from your comments [and I didn't tried hard], so what are you doing - are you installing aux gauges in car which doesn't have them and never had before? What parts do you have?
Yes, temp sender is totally different [and small] and it's in different place as well - in 5 pot engines it's mounted in oil pump in front of engine. I forgot was it on right [driver's in UK] side or front, I think front. Wire originally goes around engine on it's right side. If your car doesn't have any mud guards below engine compartment, you should see it relatively easy - there will be either sender or plug in it's place. |
#38 | |
Thanks. |
#39 |
You have only one bare gauge and nothing else? Where are you planning to put it?
As I said earlier, it's normal that that gauge goes max without proper sender connected. |
#40 | |
As already stated we have tried a new temporary Sender to Gauge cable but without success. General feeling seems to be that it is a faulty Sender. We are happy to try anything else. Thanks |
