Classic Audi » Technical » Mech/Tech » Electrical problems » Audi 80 Cabriolet horn not working.
Old 18-09-15, 08:06 PM   #21
Flying Frank
Flying Frank's Avatar
Thanks Bruce, but I'm not crowing just yet. Once I've sorted the niggles I'll settle back , relax and enjoy it but until then I'm just waiting for it to bite me!
Old 18-09-15, 08:09 PM   #22
sinbin5t
sinbin5t's Avatar
You will sort it mate i am sure with help from the lads on here
Old 21-09-15, 07:57 AM   #23
Ben
Wheels are definitely going to be changed but am having to pace the cash flow!
http://www.classic-audi.co.uk/forum/...ad.php?t=33661 be quick though, they don't come up often and are a bargain
1992 80 quattro 20vt
Old 21-09-15, 10:23 AM   #24
Flying Frank
thanks Ben , agree they are great value but am going for the old classic ( Craig favourites ) wagon wheels. Already purchased from Shaun5 . Appreciate the tip off though.
Old 21-09-15, 11:13 AM   #25
andydunn2
Ragtop Collector
Frank,
Very nice cabby sir!!
Ok firstly you car was fitted with an airbag as standard as it's the later facelift model (pre final edition).
Might be an idea to change the other sensor behind the passenger side head as they are cheap and do send a signal to the temp guage, as well as the MFTS one that you just changed behind the drivers side head. How is you fuel guage is it working correctly? Seeing as the wiring to the horn/airbag has been butchered is it possible the wiring behind the clocks has been damaged as well? Do you have one or two fans for cooling the radiator, there are staged and I think one kicks it at around 98c and the other comes in at around 110c, if it's one fan it has dual speeds and kicks to the higher speed at around 105c. Fans shouldn't really come on until you are sat in traffic or idling for a long time though. Might be an idea to change the fan switch on the rad as well, again cheap to buy.
Wheels all your choice, 15's or 16's give the nicest ride, I prefer the 17 inch boleros but they tramline like hell.
Andy
"Earl" 1998 2.8 V6 Cabriolet
Old 21-09-15, 01:07 PM   #26
Flying Frank
Originally Posted by andydunn2 View Post
Frank,
Andy
Hi Andy, many thanks for the helpful comments above.
With what has already been suggested and with your comments too, I'm happy to report that I've found the culprit but it has thrown up another question.
With the last wreck of the road that I bought ( the red Audi 80 Avant TDI auto ) came a box of spare bits, wing mirrors , switches and also a spare instrument binnacle. So before lunch I whisked out the instrument binnacle from the Cabrio and having checked that most bits looked the same , plugged the new binnacle into place and here's the result.
Only problem is that this "set" indicates 130,000 miles as opposed to the cars original which shows 113,000. Another issue is that the tacho is reading too high. Probably because this is for a 4 cylinder car and the Cabrio is a V6 I'm guessing.
Any ideas? As I don't know where in the binnacle the original problem lies, I'm a bit wary about dismantling the units and swapping stuff over as I might end up worse off with two fooked binnacles knowing my electronic skills !!
Answers on a post card please or here if you prefer.
Only one fan on this car so propose a road trip in a minute to test out the car with the new temp gauge in place and see if the fan does get around to firing up.
Thanks for your input and help. See you in Looe sometime perhaps? Hope so.
Frank.
p.s. Airbag bulb coming out in just a minute.....
Old 21-09-15, 01:42 PM   #27
Ben
The temp guage should be held in by two nuts, loosen then tighten them up again as they are the electrical connections.
Old 21-09-15, 02:21 PM   #28
Flying Frank
Are you thinking the duff one is just a case of bad contacts then?
Old 21-09-15, 02:56 PM   #29
sinbin5t
sinbin5t's Avatar
Are you sorted now Frank ? i sure hope so
Old 21-09-15, 03:44 PM   #30
ChrisG
ChrisG's Avatar
Lovely colour Frank ( had a kingfisher A3 T Sport late '99- 2002)
Electrical gremlins are the pits as I found out earlier this year..... slowly and methodically is the answer and a voltmeter is helpful- or even a bulb with a probe.
Don't dislike the wheels but 10 spokes will look better.
