Classic Audi » Technical » Mech/Tech » Bodywork, glass & exterior fitments » Electric to Manual Window Conversion on 1984 Coupe GT
Old 29-03-18, 03:42 PM   #21
a1quattro
Default good news , solved porblem
Thanks to anda for sending measurements of the motors incl cables from side to side , mine where the same so I knew for sure I had the correct coupe units , so took a look at my inner door skin and compared a pic from the sellers /donor car . the bolt fixings for the up down rail at the top on my door skin there are only 4 holes [only two are used for the rail ]but on donor car [ both 1984 coupe gts ] there are two sets of 4 ,with a longer re-cess for the extra 4 holes , which tilts the rail more upwrite , so tmrw I will drill the extra holes req , may need to fit some small spacers due to my doors not having the longer re-cess , but pretty sure it will work , hopefully will update after
a1quattro is offline   Reply With Quote
Old 29-03-18, 06:50 PM   #22
andya
andya's Avatar
Glad I could help ray
1985 Coupe Quattro
1986 Coupe 1.8 weber carb
1987 Coupe 2.2 GT
