Classic Audi » Technical » Mech/Tech » Electrical problems » radiator fan......ON......!!!
Old 02-02-10, 04:21 PM   #11
the rad fan switch only works through the ignition.
This is the after run circuit playing up as it works when the ignition is off.
Relay or afterrun sender are the most likely culprits
1991 90 quattro
Old 11-02-10, 12:09 PM   #12
SteveCat
SteveCat's Avatar
Default .
Would anyone know where the Afterrun Sender is located on these cars?
I have same problem,and Ive pulled every relay also,and it still keeps running.
I've just disconnected the cooling fan for now,as the engine doesnt really get hot enough on the journeys Im doing at the moment.
Hope this isnt too silly a thing to do
Awaits flaming!
Mercedes E220 Sportline Coupe
Old 11-02-10, 02:05 PM   #13
missfire
making wooden things
missfire's Avatar
im saying nothing....
Old 11-02-10, 02:21 PM   #14
SteveCat
SteveCat's Avatar
Default .
Yeah I take your point.
Its either flattened battery,which needs a new alternator too....or a cooked engine....
Think I will stick with the battery,and reconnect straight away! Sillygroom!
I take it you dont know where the sender is then Mr Fire?????
Old 11-02-10, 02:25 PM   #15
missfire
missfire's Avatar
Originally Posted by Groomus View Post
Yeah I take you point.
Its either frazzled battery....or frazzled engine.....
will find out today....taking engine apart as i speak..!!
will update you as soon as i can..
wiring diagrams in haynes.............some of my wiring fits the original diagrams and some fits the supplement.....typical haynes...
Old 11-02-10, 02:33 PM   #16
SteveCat
SteveCat's Avatar
Default .
Thats handy.
Nice one matey!
What is Mr Missfires name anyhow??
Flambus??
Old 11-02-10, 06:08 PM   #17
missfire
missfire's Avatar
Thats handy.
Nice one matey!
Flambus??
hello.......this is the page......!!
http://www.sjmautotechnik.com/troubl...ing.html#after
for you that is..!! looks like the turbus models have an electric after run water pump too...but there is a pic of the after run control unit on that page.. and the sensor...on the main coolant flange..
but i dont have that sensor........so ill have to keep looking...
i probably do have the control unit though...so thats a start..!!
Mr Duncan Missfire..
Old 11-02-10, 07:45 PM   #18
SteveCat
SteveCat's Avatar
Default .
Bloomin' Marvellous Dvnkvm!
Many thankings
I shall have this sensor out and clean and check the resistance,along with the other two.
Im blowing cobwebs off engine components that haven't seen the light of day for 26 years here.
Surgeons touch needed,Im going in!
Old 11-02-10, 07:48 PM   #19
Blackrat
Blackrat's Avatar
Spookily enough...my 200 hadnt seen a live battery for a few years and when I connected one the fan came on straight away!!...I didnt look to see what the problem was as I had too much to do but it seems to be prevelant to the 200.
I await Groomus's surgery and prognosis
1982 quad light GT5 S .......92,000..
1976 wife... mileage unknown.. in daily use
Blackrat is offline   Reply With Quote
Old 11-02-10, 08:11 PM   #20
SteveCat
SteveCat's Avatar
Default .
Groomus has just spied that the bulletin Duncan posted a link to pertains to 1986-90 cars.
Mine is a 1984 modelus.
Hope it still applies.
Cant hurt to clean and check them anyway.Wish I had a garage.Its cold out there...and dark......and Im scared
type 85 radiator john johnson Parts For Sale 0 30-08-09 07:22 AM
kv radiator slacky Parts Wanted 4 31-07-09 08:35 PM
10v Radiator question djb1607 Engine 7 31-07-09 05:31 PM
Radiator, will this one fit? Scarlet Engine 2 07-05-09 06:25 PM
New Radiator poopcoupe Parts Wanted 28 16-01-09 05:28 PM
