Classic Audi » Technical » Mech/Tech » Engine » any ideas ??? won,t fire up
Old 23-01-10, 09:08 PM   #11
jack1
is this to suit the metering head with part number ending in ....063?
Old 23-01-10, 09:09 PM   #12
Is the control plunger,sticking from fuel gum or rust?Just a thought?
Is it k-jet on a 100 type 43?
Old 23-01-10, 09:18 PM   #13
jack1
will check but 99.99% sure its k-jet
Old 23-01-10, 09:24 PM   #14
I,ve borrowed a Bosch book off Brother,I,ll have alook through and try help you?
Old 23-01-10, 09:44 PM   #15
missfire
making wooden things
missfire's Avatar
hello,
its flooding the plugs the mechanic tried adjusting but to no avail
was he pissing about with the 3mm allen screw between the distributor and the air flap....????
that is only for idle mixture....
overall mixture is determined by control pressure i think.....(and the shape of the cone that the air flap sits in)
the system may have been adjusted previously to account for wonky components..
Old 23-01-10, 09:55 PM   #16
missfire
missfire's Avatar
does the system have a warm-up regulator...?
there was a trick people used to pull in order to adjust the control pressure..
they would drill a hole in the back of the warm-up regulator to access an allen screw..then adjust pressure/mixture from there..
if you have a warm-up regulator you could un-bolt it from the block (but leave the fuel lines on it) and have a look for any drilling....
will second that one
Old 24-01-10, 07:23 AM   #17
jack1
thanks for your replys and im making a list(not for santa as that would be for a 2005t) and will pass it on to the mechanic
Old 26-01-10, 10:17 PM   #18
jack1
any ideas where to get the relay for the k-jetronic?
Old 26-01-10, 11:14 PM   #19
steveb
steveb's Avatar
the one for the fuel pump ? Pete reeve quattro corner http://www.quattrocorner.com/
[FONT]
'76 Leyland Princess 2200 HLS
'79 Scirocco storm
'84 WR
'89 coupe quattro
'01 A2 1.4 TDI SE
'14 A3 1.4 TFSI COD
[/color][/size][/font]
Old 08-04-10, 10:28 PM   #20
jack1
well folks i collect my type 43 5e tomorrow after nearly 4 months with the mechanic and guess what, its still a non runner
need some ideas ? Micky General Chat 25 25-01-10 11:37 AM
Problem, anyone any ideas? Sie! Suspension & Brakes 15 08-07-09 11:26 PM
Anyone any ideas ! Audi Dec Suspension & Brakes 0 24-06-09 11:53 PM
ideas please Micky General Chat 14 08-05-09 04:39 PM
