Classic Audi » Technical » Mech/Tech » Engine » Black Sooty Smoke
Old 23-11-09, 09:26 AM   #11
BW2309
Banned
Hey up Matrtyn. You ought to have called me bud. I would suggest that as stated, it needs a good boot-full or perhaps a re-tweak. Blak smoke is a sign of too much fuel (or too little air - blocked filter etc) so nothing to owrry about. Give me a call if u need to buddy
Old 23-11-09, 10:26 AM   #12
Hi Ben
she ran fine over the welsh hills so not to worry too much
One thing that I have noticed. Now we have routed the rocker cover breather pipe back into the air filter assembly, the paper filter is starting to get covered in oil vapour. I wonder if this is ulimatley causing a problem with air flow and the mixture as the filter starts to clog up
Old 23-11-09, 10:36 AM   #13
20vcqdriver
20vcqdriver's Avatar
Or carb freezing issue. Had this all the time in my 1.9GT with weber carb many years ago as soon as the air temp dropped below 8 degrees and on any trip too. The fact that I had no diverter for the hot air from the exhaust was to blame.
Regards oiled up filter you could fit a catch tank to stop the heavier oil particles, has made a big difference to my car with far less oil coating the inlet pipework..
Old 24-11-09, 07:36 PM   #14
Gaz
Gaz's Avatar
would very much like to see your catch tank install.. do u have pictures? And where did u buy your catch tank from?
(p.s, sorry for the slight thread hi-jack)
cheers.
Old 24-11-09, 09:36 PM   #15
cheers.
was just thinking the same thing Gaz
Old 24-11-09, 11:11 PM   #16
20vcqdriver
Made it from some scrap stainless steel tube in our workshop. Undertray is off at present so will whip it off and take some pics. Needs a clean anyway whilst car on SORN.
Pic is of a similar homemade one I had on the 7A engine (top right).
White odourless smoke! Emjay Electrical problems 27 21-01-11 12:40 PM
Help 80 TDI Terrible Cold Start White Smoke StompOn Engine 3 16-08-09 05:59 PM
turbo and smoke issue yet again 20vcqdriver Engine 53 23-06-09 03:13 PM
Black wr sandhurst darreno'd' Spotted! 0 14-04-09 03:08 PM
