Members: 19,823 | Total Threads: 40,096 | Total Posts: 471,131 Currently Active Users: 5526 (0 members and 5526 guests) Welcome to our newest member, BuddyInons |
#11 |
...probably because of the over-confidence factor engendered by the 'I'm driving a quattro' feeling. As Scotty from Star Trek said: "I cannae change the laws of physics Captain". And neither can a quattro, good as it is. The word 'masking' is the key one - all that is happening is that the aquaplaning is not as apparent - but it is still happening. And when it really does let go, the car is going a lot faster than some lesser vehicle. Someone once said that due to this factor, quattro drivers have much bigger and better smashes than anyone else. Though ironically, the quattro I wrote off was on a nice dry day (diffs unlocked of course). Still gutted.
#12 | |
#13 |
I don't think it's problem with mk1 quattro, because it does have lockable center dif. ...unlike later quattro generations with torsen, which means car have awd only in motion but standing car have bigger chance to get stuck than fwd
On enough bad surface, of course. Btw ir remember one man, who believed that diff lock button in he's B4 2.0q locks all wheels - I explained him, what does this button really does ![]() P.S. BasilNZ thanks ![]() |
#14 |
#15 |
i take it the quattro when rallying would have the diffs locked at position 2 unless it was on tarmac? or did the rally cars have a different system.? can the diff locks on a type 85 be engaged/disengaged at road speeds or can this cause damage?
#16 |
The rally cars did not come with a centre diff, they were a solid drive to front and rear (as if centre diff was permanently locked).
#17 |
Yes the Rally quatts were a solid drive, which is why they were ' a pig ' to drive ( Malcolm Wilsons words not mine). The early Subaru Legacy that McRae drove was also solidly locked and would not turn unless you really provoked the car by severly upsetting it's balance. I'm not sure what effect having the centre diff locked would have if locked for a long time but I think it's fine for short periods at least.
#18 |
This might be helpful...
http://www.kvquattro.com/techdocs/diffLocks.html Essentially, you could drive around with the centre diff locked all the time, but it serves no purpose at all on dry tarmac. You will find that the drivetrain makes funny noises during tight turns. That is not to say there are no consequences - as the wheels cannot turn freely in relation to each other the drivetrain will be under greater torsional (twisting) stresses which will definitely shorten the life of drivetrain components if constantly locked, diffs will wear out more quickly etc. Tyres will also wear out more quickly due to being scrubbed against the road surface on turns. Of course, none of this matters on a rally car. In extremis, something could snap, but the quattro drivetrain is very robust so it is unlikely to happen unless there has been serious abuse. I wouldn't treat my car in that way though. As I said, there are no stated speed restrictions for employing diff locks for mechanical reasons, (though for handling reasons high speed use of the rear lock is definitely not recommended), but as the instruction manual says, you are using them when it is slippery, so you should not be driving fast anyway. It does state that the rear lock should only be used in extremely slippery conditions to start the car off, and to turn it off when moving. The later cars disengage the lock automatically at 15mph for this reason. |
| lockable front diff?/Torsen front diff? | Gaz | Transmission | 10 | 16-01-10 01:54 AM |
| 80 coupe locks for a saloon? | silverStoned | Bodywork, glass & exterior fitments | 7 | 06-01-10 09:52 AM |
| ABS and Diff locks | andy | Transmission | 8 | 11-11-09 10:10 PM |
| WR diff locks | andy | Transmission | 6 | 24-08-09 11:53 AM |
| 80 doors locks | maynd | Bodywork, glass & exterior fitments | 9 | 28-01-09 11:26 PM |
