Members: 19,800 | Total Threads: 40,093 | Total Posts: 471,102 Currently Active Users: 1181 (2 members and 1179 guests) Welcome to our newest member, Dennisinvap |
#11 |
you havent.....have you
![]() ![]() ![]() ![]() ![]() fix this one first before you get any more ![]()
#12 |
No,no more cars bought honest,i am saving for a nice UR,
![]() ![]() ![]() maybe metallic blue |
#13 |
DAM... red is the fastest
#14 |
Finally managed to get old ignition out after removing steering wheel ,instrument panel,getting the replacement in ? I've tried just about every angle.Do i need to drop the steering column or take out dash?
![]() ![]() or maybe i should get some![]() ![]() ![]() |
#15 |
![]() ![]() ![]() go back to it tmw
#16 |
Hm, unfortunately, I don't remember, how I did it, if u are talking about ignition switch. If the dashboard prevents u from placing it in place, unscrew theese two bolts that are holding dashboard on right side, that will allow u to pull dashboard back for some cm's, I think, that must be enough. The same thing is needed, when replacing air con fan, at last on LHD B3/B4's
#17 |
Thanks for the info.ie 2 bolts managed to get ignition lock fitted:rock
Replacement instrument panel arrived ,plugged it in everything working but no autocheck,hmm.The old one had 3 plug ins and had a fuel consumption computor,this one has only 2? Is that another failure? I have abs and battery light on the front.Do i need a special instrument cluster for 90 20v Sport which has slightly different spec.Still got to bleed brakes and check ![]() ![]() ![]() |
#18 |
So, does it have two warning lights instead of auto check as base speedometer? As we can see here and here, third connector - C - have only one purpose - auto check. I only don't get the idea where connects B connector, because it have only 10 pins, it isn't like other three other connectors, but it doesn't care anyway - it's for on board computer and not autocheck. As I said - in your case I would dismantle speedometer and look for broken electrical paths and when found, solder them with some wire, that's the lightest damage possible there
![]() P.S. I still don't get the idea how does MOT can tell before driver that calippers are stuck? When they are stuck, "driver feels power loss of car and wheel is unusually hot even after some miles in city" ![]() |
#19 |
No,the replacement has autocheck but i cant get it to work,I will try what you suggest and open up the faulty instrument unit and have a look cheers m8
| would you swap a UrS4 for a 90 quattro / non quattie 20v sport/ non sport? | quattrokid | General Chat | 33 | 05-09-09 07:50 PM |
| engine MOT failure.... | quattrokid | General Chat | 17 | 21-05-09 08:24 PM |
| Headgasket failure seal.... | Puglife | General Chat | 1 | 07-03-09 03:26 PM |
| Help! Cambelt failure! | Lankytim | Engine | 25 | 17-09-08 09:34 PM |
