Members: 19,821 | Total Threads: 40,098 | Total Posts: 471,146 Currently Active Users: 8121 (2 members and 8119 guests) Welcome to our newest member, BuddyInons |
#11 |
hi martc i done this to my quattro ur last year thay are wind back but , the brakes where shot so it was new aero quip hoses all round, 2 new back brake caliber ,new disc all round, new pads all round also new brake fluid all round yes expensive but worth it in the end ,good luck with the job my friend
#12 | |
Black Coupe Collector
Thanks!
95 UrS6 87 Coupe Quattro |
#13 | |
#14 |
Hi Martc, i found when i did my flex pipes last year for my MOT that you need to be careful when trying to undo the flex pipe from the copper/metal pipe due to corrosion sometimes you think its turning but infact its twisting the metal pipe and can fracture.In the end i cut the flex pipe off at the bracket being cautious not to damage the end of the metal pipe .
This was just one of my concerns i came across. Thanks Tony |
#15 | |
![]() Horsepower is the force that determines at what speed you hit the wall, Torque is the force that determines how far you take the wall with you after you hit it. |
#16 | |
#17 | |
2. Squeling brakes: try doing a few emergency stops from 70mph. Might be that the pads have got shined up after only light use. 3. As stated only need wind back tool for rear brakes. Once refitted and brake pedal pumped a few times keep the pedal pressed whilst yanking up the handbrake a dozen times to set the adjuster correctly. Good luck
#18 | |
Used high temp brake greese this time instead of cooper slip. My rear calipers were also seezed up, now everything appears to working as expected ![]() Nige thanks for the offer of the loan of the wind back took, luckily I had a 12mm allen key so all was good! All I have to do is get the new bushes put into the anti roll bar, and fingers crossed for the MOT on Saturday ![]() Nige thanks for the
#19 |
just spent two hours serching for it, found it and now you don't need it
![]() No worries really mate, glad you got it sorted
#20 | |
- permission to kick my ass on Sunday ![]()
| Audi 100 NF engine KE Jet fuel pipes poss AAR | pimpdriver | Parts Wanted | 2 | 25-04-15 06:24 PM |
| UFO brakes on Audi V8? | NBirkitt | Suspension & Brakes | 0 | 25-05-09 05:01 PM |
| Audi 100 NF engine KE Jet fuel pipes | pimpdriver | Parts Wanted | 0 | 30-03-08 10:46 PM |
| Audi 100 NF engine KE Jet fuel pipes | pimpdriver | Parts Wanted | 1 | 29-01-08 11:45 AM |
