Classic Audi » Technical » Mech/Tech » Transmission » B2 90Q rear gearbox seal
Old 23-06-21, 02:56 PM   #11
David42U856
Originally Posted by Groundhog View Post
Cap head bolts are usually harder than standard bolts so make sure you have a keen drill and bit. If you have one a number 8 multi splined sockets ( used on drive shaft bolts) it can be hammered into the cap head....has always worked for me 99% of the time.
Unfortunately, the multi-splined sockets didn't work. I tried three or four times with the 8mm version but was unsuccessful. The next size I have is 10mm, so a big step up - I guess I should try it though. I'll soak it with release oil for a while. I got the loosened screw out and have ordered new ones. I think I'll try installing two new screws with loctite and see if that solves the issue. I've got a bad feeling about drilling the top off the damaged screw as I'll end up with a dowel holding the damper/counter weight in place and a flange that stops me removing it. If that happens I'm screwed.
Incidentally, the screw I removed has a vertical crack in the side of the cap head. Not a failure mode I've seen before. Have you ever seen a cracked bearing support housing as a result of loose/missing screws? If the screw can crack I guess the bearing housing can too.
David42U856 is offline   Reply With Quote
Old 23-06-21, 03:03 PM   #12
David42U856
Image of cracked screw (90Q rear output shaft bearing housing)
Old 23-06-21, 04:06 PM   #13
I take it there's no room for a grip socket in the space available ?
These have saved my bacon a few times on rounded cap bolts
1991 90 quattro
Old 24-06-21, 07:59 AM   #14
Groundhog
Sorry to hear it wasn’t successful. It would seem someone has been there before you and failed. The split bolt, I suspect, is as a result of a previous removal, I’m guessing someone hammered something to big in there, it had the desired effect in that I would imagine they removed it but then failed on the last bolt which is why the splined socket trick won’t work. I would do as you said replace the two and keep your fingers crossed.
I have never known a housing to split.
Old 24-06-21, 08:08 AM   #15
tractor Dave
Have you got a mig welder?
Weld a small bolt in there.
Don't forget to remove you ecu's first.
Old 24-06-21, 02:35 PM   #16
David42U856
Unfortunately, it's about 10mm down inside a counter-bore - so pretty inaccessible. Thanks for the suggestion though. I've never used a grip socket - sounds like it worth having in the tool kit.
Old 24-06-21, 02:38 PM   #17
David42U856
I don't have a mig welder. The head is down inside a deep counter-bore though so there's no access. Thanks for the suggestion though!
Old 24-06-21, 02:42 PM   #18
David42U856
Waiting for the bolts and CV joint grease to be delivered. Hopefully they arrive in time to put it back together on the weekend. The grease in the prop-shaft CV joints was pretty dried out so I plan to clean and re-grease.
Old 24-06-21, 03:58 PM   #19
This is the type, https://www.ebay.co.uk/itm/221924576...IAAOSwXWZgtjkC , very handy things to have but sounds like your bolts might just be un-accessible for them ?
Old 30-06-21, 08:31 AM   #20
David42U856
Thanks for the link John. Much appreciated.
Tags
90q, gearbox, rear output shaft, seal
