Members: 19,769 | Total Threads: 40,089 | Total Posts: 471,075 Currently Active Users: 1617 (5 members and 1612 guests) Welcome to our newest member, Danielcrode |
#11 |
Until recently I'd have agreed with you, but having had a 'gasket' comparing session with Pete Berry at White Cottage Quattros, I was amazed to find there are quite a few differences between a WR/KE type head against and MB/MC head and then with an ABY/KV type... I've lumped them together like that because the gasket bore of a KV is bigger than an ABY, which suggests an ABY gets 2226cc from a smaller bore and longer crank throw against a KV which suggests a wider bore and shorter crank throw. Suffice to say, there are differences with the galleries between the block and the head over the development of the 5cyl engine and one big one is the front water gallery. The easiest way is to order the gaskets for a KV and the chosen head, and align them on the kitchen table... Suffice to say, I'd put a £1 on the KV gasket cylinder bore being bigger. However, there's no reason ultimately, why you couldn't get a gasket machined out to match, at the end of the day....
#12 | |
Banned
#13 | |
==>PUGSPORT!<==
7a engines come about readily (i've bought 3 so far one fully rebuilt and they all totalled under £500).... pistons are expensive for turboing, conrods are £250-300, crank is fine, water manifold from turbo engines can be fitted with about £150 of machining to allow the additional watercooling holes. £200 engine + £1200parts = £1400 for an engine that you could essentially with manifold and turbo run 400bhp on....
#14 |
#15 | |
lol |
#16 |
The bore is slightly larger on a 7A 82.5mm compared to 81mm for the KV but the main issue is the pistons. The 7A pistons are as shown and completely different to the KV which has a small bowl. The 7A normally runs a 10.3:1 compression ratio so you will have a KV with 20v head and low compression and possibility of valves hitting the piston. Cheaper to get a whole 7A with larger capacity which it needs to compensate for the loss of torque at low revs.
#17 | |
![]() or could i just take a complete 7 A engine and fit my crank and pistons? and have some head work done to the 7A ? would that be any easier? ![]() |
#18 |
David (20vcqdriver) has had the 't'shirt and full hospitality pack for modifying KV's, fitting 20v 7A's and ultimately winding up with a 3B... I'd guess if David says it's not worth hassle, it's not worth the hassle...
#19 | |
#20 |
Right then so easyest and best thing for me to buy is eather a 2.2t 10v or a 2.3 20v n/a so whos got what
| 90 needs new Cylinder head | naffa | Cars For Sale | 1 | 19-12-09 07:43 PM |
| WR head | quattrokid | General Chat | 16 | 20-05-09 07:53 PM |
| CD-less Head unit??? | Gaz | In-Car entertainment | 13 | 22-04-09 11:10 AM |
| Wanted 20valve head. | 4v6 | Parts Wanted | 0 | 17-07-08 09:26 AM |
