Classic Audi » Technical » Mech/Tech » Engine » Water flange with temp sender on.
Old 11-04-17, 07:22 PM   #11
I wouldn't recommend attempting to take the flange off.
Slide back the rubber boot. Undo the wiring plug first.
The sensor just unscrews - 29mm socket / spanner.
1991 90 quattro
Old 11-04-17, 07:33 PM   #12
Duffy3074
Yep no need at all to remove the flange
Just a world of hurt that way if it goes wrong
Old 19-04-17, 07:53 AM   #13
Crossle
Crossle's Avatar
Sorry, maybe a stupid question but I'm no mechanic! Do I need to drain the water to change this part?
Crossle is offline   Reply With Quote
Old 19-04-17, 08:10 AM   #14
Duffy3074
just the sensor?
No, a small amount will come out but not enough to justify draining it, just have the new part good to go straight in.
Needless to say, do it with the engine cold
Old 19-04-17, 08:13 AM   #15
No just have the new one ready to go in, as Royston said get the fuel pipe out the way.....with the dipstick removed make sure the tube is covered/blocked so you don't get petrol down there!
Hopefully you'll only lose a small amount of coolant as you swap the part but worth while after it's fitted raising the expansion tank and loosen the heater and rad bleed points to get any air out.......you'll likely need to top up a little.
Old 21-04-17, 07:42 AM   #16
Crossle
Crossle's Avatar
Great info thanks very much
