Classic Audi » Classifieds section » Parts Wanted » FUEL PUMP RELAY for Audi 200
Old 08-10-15, 07:43 PM   #11
Audi?
Flippant, I know, but you'd be surprised how much you can still get, and at reasonable cost compared to Internet auctions.
(24) 8A0951253
contact close relay / for fuel pump / relay location: / F >> 44-F-300 000*
10 / KG,JY
(24) 191906383C
contact close relay / for fuel pump / relay location: / F 44-G-000 001>>*
10 / KG,JY
It might be one of those, but I won't be able to check for a few days. I do have a couple somewhere which need fixing.
Google search shows both to be without fuse socket Apparently the difference between both might be power rating.
Old 08-10-15, 07:54 PM   #12
Hanuman
Hanuman's Avatar
Interesting. I pulled those numbers from Vagcat!
Old 08-10-15, 09:01 PM   #13
John Clayton
I found the info you mentioned above...
http://www.isham-research.co.uk/quattro/tech.html#elec
Am I right in saying that the sub-pages relevant to my car's engine are as follows?
MB ECU codes, diagnostics and pinouts
MB ECU self-diagnosis
John Clayton is offline   Reply With Quote
Old 08-10-15, 09:56 PM   #14
audicoupeparts
I think I took similar(same) relay from an ng engined coupe last week
Will see if I can find it
Old 09-10-15, 07:33 AM   #15
If you have a 1B engine then yes, the MB instructions are correct for your car
1991 90 quattro
Old 09-10-15, 09:42 AM   #16
Hanuman
Hanuman's Avatar
Being a 1987 vehicle, wouldn't it be KG engined, still?
Old 09-10-15, 10:39 AM   #17
The kg engine doesn't use that relay though.
It's a different method for reading codes
http://www.isham-research.co.uk/quattro/codes_kg.html
1991 90 quattro
Old 09-10-15, 11:19 AM   #18
John Clayton
How can I tell whether my engine is KG or 1B? Based upon the fact that it needs the specified relay for its fault codes, am I right in saying that it must therefore be a 1B engine?
Old 09-10-15, 12:48 PM   #19
Will be on your V5 or also on the side of the block.
it could be the garage are talking out their arse
1991 90 quattro
Old 09-10-15, 01:31 PM   #20
John Clayton
According to the V5 the engine no. is: KG022506
