Members: 19,748 | Total Threads: 40,088 | Total Posts: 471,064 Currently Active Users: 1591 (2 members and 1589 guests) Welcome to our newest member, rc24Vak |
#11 |
21 + 19 = OLD!
Do you think getting the new rad in this should sort out the problem or is there anything else I should look at?
audiless........... |
#12 | |
If the rad is leaking you might as well bite the bullet and replace it and not have the worry of it failing in the future. hope this helps |
#13 |
21 + 19 = OLD!
Nice one Baggee, any idea where I can get stat?
#14 |
if you are not losing water then doubtful it's a leak. You will see or notice it ie constantly topping up the system or damp patches where the car is stood.
Possibilities are thermostat. It may be sticking and would be cheap to replace. Could also be a blockage in the system or possibly an air lock restricting water flow. I would first flush the system to remove any air blocks or physical blockages and top up. Just use water. If this works and the engine runs fine then simply do a water replacement with a suitable antifreeze water combo. If you are happy that the system is completely full and the problem still persists then go for the thermostat. Also may be worth checking the water pump. Assuming it is belt driven (I don't know for sure on this) it could be the belt is loose and not turning the pump fast enough. Thats how I would check it anyway |
#15 |
hey Chris, great minds and all that
![]() Stats you can get from any motor factors |
#16 |
Word leak means that something is leaking, right?
So, there is no coolant loss, so coolant isn't leaking, what else can leak - air at atmosphere pressure leaks into coolant? ![]() My B3 have a leak, old rubber hoses leaks a little bit coolant, if it heats up to 95c, so if there is dry weather, I can see on cover, that's beneath engine compartment, some coolant and I can smeel it. Whatever. What can it be? I have seen some radiators that have corroded so heavely, that theese "ribs" or whatever it's called can be ripped off with a match - because there on joints are not metal but oxide, it doesn't transfer heat. It can be termostat, yeah. Water pump? poopcoupe, how about heat from heater when car is standing and iddling? But I don't think it's pump anyway. And belt it can't be, I looked in ETKA, looks like water pump is driven by cam belt, am I right? And if it wouldn't be cam belt, it would make some sound when slipping anyway. |
#17 |
21 + 19 = OLD!
Right, Im going for the system flush this week, also we noticed on the bottom of the car when lifted that there seemed to ne some green coolant on the bottom of the engine. Now whenparked there is no sign of leaks but htis coolant is visable on the underside. I have ordered Stat to change. Apparently my rad has seem better days so after flush if that hasnt worked I will change rad. Now my engine is filthy so Im getting the engine bay cleaned, then I can see if any fresh leaks etc. Water pump is fine because if on way out it wouldnt work when up to speed? Does this sound like the right coarse of action?
#18 | |
Regards. thefirstdoc1 |
#19 |
If water pump is dying, it can make nice sounds when iddling, it can make coolant loss without sights and it can make too weak flow of coolant in lover rpms.
thefirstdoc1 what - termostat in radiator? ![]() |
#20 |
21 + 19 = OLD!
msh - what sound does the pump make as Ive got various strange noises going on when hot!
| radiator fan......ON......!!! | missfire | Electrical problems | 25 | 12-02-10 05:30 PM |
| type 85 radiator | john johnson | Parts For Sale | 0 | 30-08-09 07:22 AM |
| kv radiator | slacky | Parts Wanted | 4 | 31-07-09 08:35 PM |
| 10v Radiator question | djb1607 | Engine | 7 | 31-07-09 05:31 PM |
| Radiator, will this one fit? | Scarlet | Engine | 2 | 07-05-09 06:25 PM |
