Members: 43,073 | Total Threads: 40,086 | Total Posts: 471,053 Currently Active Users: 1040 (3 members and 1037 guests) Welcome to our newest member, MariaPeera |
#11 |
The diameter of the shaft was greater on the replacement unit, which is why they supply them with new caps and why you cant re-use the originals.
#12 |
It's the shape of the insert - the cap is designed to fit around it to clamp it in place.
You also don't use bump stops if you go with Bilstein as they have internal ones
#13 |
Aero Advocate
Do the top caps come with the inserts then or are they something u have to source separately?
#14 |
typically aftermarket shocks will come with the caps.
From the dealer, you need to buy caps as individual items
#15 | |
#16 |
Paint marks should be at the bottom of the spring if they are OE
