Classic Audi » Technical » Mech/Tech » Engine » audi 90 poor cold start......
Old 25-09-08, 11:35 AM   #11
There is better way how to check cold start injector - remove it, when engine is cold, then crank engine and look, does this injector sprays fuel or not. And to check if it's not leaking, just unplug wire from it. Only disconnect center wire from distributor and target injector at safe point
Old 25-09-08, 11:49 AM   #12
20vcqdriver
20vcqdriver's Avatar
Default cold start
Only problem with this is having fuel spraying everywhere, having then to plug the hole in the manifold and possibility of damaging the fibre gasket. Have you tried starting it from cold with the cold start injector unplugged altogether to see if it makes any difference?
Old 25-09-08, 11:56 AM   #13
Everywhere? Have u ever seen one nozzle in action, really? Goddamn it, british fears from fuel are unmeasurable Just extinguish your cigar, and nothing will happen
Old 25-09-08, 12:30 PM   #14
its the thermotime switch on the back of the block and i agree with removing the cold start injector and cranking it over , if its goosed it dribbles if anything at all. if it works fine it gives a nice light mist or puff of fuel for a few seconds approx just to get it running . been there and done that on one of the wr's this year
Old 25-09-08, 05:43 PM   #15
johnboy
Thumbs up
blimey guys thanks alot for your info some good things there to try! i have already done a few checks but fuel pump relay and fuel pump itself sounds like the best next things to look into! as said befor thanks very much big thumbs up to you all!!!!
johnboy is offline   Reply With Quote
A4 1.9 TDi 1997 'R' (hard to start from cold) The Milkman Engine 5 14-10-09 07:41 AM
1995 Audi Coupe wont cold start!!!!!!!! aheath55499 Engine 2 08-10-09 09:35 PM
mb cold start pipe arm Parts Wanted 4 21-08-09 04:04 PM
2.0 GT5 cold start problems splittie67 Engine 5 15-06-09 06:03 PM
