Classic Audi » Technical » Mech/Tech » Engine » iginition problems Audi 1.8 type 89
Old 14-04-11, 01:36 PM   #11
quattrostyle
Small update: I haven't set it on fire yet unfortunately. It's still ain't running though, or I should say not on all 4, maybe 2 or less.
Spark plugs, leads, rotor arm and distributor cap are new. All spark plugs are completely wet almost immediately after start up, there even seems to be a bit of fuel on the pistons when I take the plugs out.
What on earth could it be? Ignition itsself, or does it have some sort of ECU? Earth wires seem to be fine, starting to think about it now, I haven't had a look under the fuse box yet.
For the info it's a JN engine.
Old 14-04-11, 04:19 PM   #12
type81
type81's Avatar
Have you changed the coil? are you getting any spark from all leads to the spark plugs?
i dont think all your spark plugs should be wet from fuel?
Old 14-04-11, 07:58 PM   #13
quattrostyle
Yes changed the coil aswell today. Haven't had a second person to check the spark on all plugs.
