Members: 43,055 | Total Threads: 40,086 | Total Posts: 471,048 Currently Active Users: 3475 (0 members and 3475 guests) Welcome to our newest member, RandallInolf |
#11 |
“Been raced and rallied”
[quote=jogi730;141577]I'm running coilovers on my 90. My set up is as follows:
4 x Bilstein B6 4 x 2.5" race springs 4 x conversion tubes I am happy with the ride height and have received positive comments it looks about right, but I am running 17" rims. HTH Cheers Chris ![]() Why have you put the spring helper between the spring base plate and the locking nut ?? it an't going to do anything there (should be sat at the bottom of the spring) and it looks like that the spring base plate is on upside down,there is a lip on the top of it so that the spring can sit on it and not rub the threads away.. ..
#12 |
jogi
i WAS WONDERING WHEN SOMEONE WOULD MENTION THAT.... LOL. ithIS IS HOW THEY WERE INSTALLED AND UNFRTUNATELY i HAVE LITTLE MECHANICAL KNOWLEDGE. i WILL HAVE THIS LOOKED AT BEFORE THE CAR GOES BACK ON THE ROAD BUT THANKS FOR THE TIP
CHEERS CHRIS
#13 |
Thanks for the replies. So I'm thinking that I could just go for the lowering caps at the front - resulting in 75-85mm drop at the front. Then fit the conversion kits on the rears. Is this a relatively easy job for a mechanic/welder? I would not want to risk doing it myself.
Jon |
#14 | |
Ok Chris just thought that you should know before the lot comes undone and puts you in a ditch or up a lampost.. ..
#15 |
jogi
I'll definitely have it looked at. Smashing her up is the last thing I would need with all the c**p that has happened to me... lol
THanks again Chris
#16 | |
No welding needed, all bolt on. |
