Classic Audi » Technical » Mech/Tech » Engine » b3 90 2.2 quattro engine wiring
Old 22-06-10, 07:23 AM   #11
sam
thanks very much, got it firing on saturday but the immobiliser wasn't removed from the ecu so it just cut out after a second. so as soon as thats removed im quite confident its going to run perfectly
Old 01-08-10, 01:04 PM   #12
sam
its aliveeeeeeeeeeeeeeeeeeeeee. just got to sort oil presure switch/gauge wires, make coolant flange and pipework from head to heater matrix and a breather setup, yipee
Old 07-09-10, 08:42 PM   #13
sam
got an issue with my starter now. is there a relay between the ignition switch and the starter? just turning the key makes a click but no power to the signal wire for the starter. but 12volts to the solenoid has it fired straight up. theres 2 wires go to the starter, well 3 but 1 is the battery feed so why's there 2 small wires? anyway relay? ignition switch at fault?
sounds fuking great reving up though
Old 10-09-10, 02:33 PM   #14
sam
no power to either of the smalle 2 wires. does at least 1 of them come straight from the ignition switch?
