Classic Audi » Technical » Mech/Tech » Electrical problems » Alarm Problem 94 Coupe
Old 04-09-09, 09:38 AM   #1
C10XYJ
Default Alarm Problem 94 Coupe
Hi Guy's,
I have discovered a slight problem with the alarm on my coupe.
When you lock the doors it usually gives off a little bleep to say the alarm is on (i assume)
but when i opened it the next day the bleeping started from the minute i unlocked the car and only stopped when i opened the door! I know the siren is under the O/S/R wheel arch. Can i disconnect this or will it cause further problems???
It seems to be intermittent at the moment any common things that would cause this ??
Cheers
C10XYJ is offline   Reply With Quote
Central Locking/Alarm problems jonr Electrical problems 11 26-11-09 09:29 PM
car alarm recommendations john johnson Electrical problems 0 26-07-09 12:11 PM
Alarm audivw Technical Info 0 01-04-08 10:37 PM
