Members: 43,040 | Total Threads: 40,085 | Total Posts: 471,034 Currently Active Users: 984 (1 members and 983 guests) Welcome to our newest member, JeffreyDot |
#41 | |
#42 |
ok i have done about 100 miles with the brake s on and all is looking good , they work alot better than 256mm setup and you can really notice the extra cooling from the discs as when they get hot you can feel them working better as they clean /deglaze the pads and keep the discs cool as you brake, i firmly believe this is down to the size of the holes , i have used many a drilled disc and to be fair they have all used about 4 to 5mm holes and i used 6.5mm, this must give better cooling than smaller holes?
where standard would fade these bite harder, obviously im bedding them in at the moment but have tried a few "sporting" stops and they stop the car in a lot closer distance and with a very progressive feeling, highly recomended conversion, ill keep an eye on the discs cracking l ![]() |
#43 |
Newt, you got a link for the adaptors?
Rich
#44 |
here we go mate
http://www.justcaddys.com/280mm_brake_adapters.html |
#45 | |
temp out of stock
#46 |
What about an S2 caliper on a standard 108 90q leg, with adapters fitted and a B3 20v disc? Would that work?.
#47 | |
I shall be fitting these at the weekend they are a bolt on up grade for golf g60 so as I' have done the hard work to finalise a audi fitment g 60 set up these will go straight on !![]() 280mm twin pots on a 4x108 quattro ! |
#48 |
#49 |
Which disc are you using?....Im thinking that a bigger wheel diameter may be needed though with S2 set up?
#50 | |
| 200 20v rear brakes on a 200 10v ?? | Dave | Suspension & Brakes | 2 | 06-12-09 07:26 PM |
| brakes sticking! | andy | Suspension & Brakes | 9 | 26-09-09 02:43 PM |
| Suspension&Brakes | capnjones | Suspension & Brakes | 1 | 01-08-09 06:23 PM |
| UFO brakes on Audi V8? | NBirkitt | Suspension & Brakes | 0 | 25-05-09 05:01 PM |
