Classic Audi » Technical » Mech/Tech » Engine » Guage readings
Old 15-08-09, 07:59 PM   #11
when the fan is off then I have a good healthy 12 to 13 volts, good oil pressure and temp. When the fan is set at speed 1 or 2 then all is OK but when I select the speed 3 then the oil pressure and voltage guages drop and the oil temp goes up. It's a definate step change. I am not too worried, it's just a characteristic of the car
Old 15-08-09, 08:04 PM   #12
"healty 12-13v" It isn't "characteristic of the car", it is dying alternator. Heatly is 14-14,5v. Check that your voltmeter shows what is really happening there [my volltmeter, for example, shows 0,5v below voltage on battery, I don't know, is that voltage drop in wiring harness or voltmeter error].
Old 15-08-09, 08:19 PM   #13
for the less than 3 thousand miles a year she does, in the daytime and dry, I am happy with 12 to 13 volts As long as she goes, stops and everything works, thats fine by me for now
Old 15-08-09, 08:26 PM   #14
Yeah, and once u will stop somewhere in the middle of the road just because alternator will stop working at all so battery will discharge and ignition will not run...
U have only one problem - nice prices to change some parts. I replaced 4 parts that wears out in alternator by spending some 6 lvl [about 8 pounds] for parts - but because I had access to hydraulic press and pneumatic pistol, without them it's impossible. Just check real voltage, alternator bearings and voltage regulator - by yourself, of course. If it's only voltage regulator, it will cost u much much less than trailer.
Old 15-08-09, 08:33 PM   #15
I have recovery included in my insurance so no worries about stopping somewhere and paying a trailer fee
Seriously though, the advice is appreciated and to be sure I will check her our when I am next under the bonnet
Old 15-08-09, 08:34 PM   #16
I hope u know how to do it.
Old 15-08-09, 08:36 PM   #17
she goes into the garage in a couple of weeks for a service and tune so I'll get her checked then
Old 17-08-09, 06:29 PM   #18
I especially for Emjay today took this photo Well, that's healty voltage - gauge shows correctly, there is only 0,25v drop in on board electrics, on battery is slightly above 14v.
Old 17-08-09, 07:08 PM   #19
PhilGee
They're the wrong way round
(i know, its a left hooker)
PhilGee is offline   Reply With Quote
Old 17-08-09, 08:30 PM   #20
thanks MSH, mine does read a bit lower so will get it checked out
Oil pressure lamp and guage wayno Electrical problems 3 10-07-10 11:18 AM
temp guage irish80sport Electrical problems 4 17-01-10 11:53 AM
fuel and temp guage zxtrevr Electrical problems 1 04-10-09 07:38 PM
Audi coupe S2 temperature guage Darron Edwards Electrical problems 4 27-08-08 07:57 PM
