Members: 43,047 | Total Threads: 40,085 | Total Posts: 471,036 Currently Active Users: 2525 (1 members and 2524 guests) Welcome to our newest member, Randywence |
Hi! Yesterday i tried the brake upgrade but no sucess!
![]() The Audi 80 is B3 from 1989 and uses single disc 256mm. Brakes upgrade: Corrado G60/ S2 calipers + audi coupe 2.2 20v quattro discs vented (276mm 4 studs). The problem is the disc crash into the "arm" (spindle carrier) Here you have some pics of the calipers and the arm ![]() ![]() ![]() ![]() I think i need to change the "arm".. Waiting for help! Kind regards, Mário |
were dose the disc touch the capliper carrier
wot year coupe dics are you using as yours is a latter b3 80
I don t know.. I m not sure even if it is from a Coupe, but i have here the box and info disc. I think is from a coupe 2.3 20v between 1990 and 1991.
When i bought i saw the list and searched by diameter and holes. And seams to be all the same. All 276mm have the same dimentions.. Delphi ref. BG2748 Overall Height = 56.2mmVented Mountings 4 Discs diameter 276mm Discs thickness 24.9mm Overall height 56.2mm Centre diameter 68mm Minimum thickness 23mm |
you may need the front discs from a 90 b3 shape or the whole front brake set up which has twin piston
capilers
hi
you can try the discs from B4 Audi 80 V6,you got the later type strut /bearing housing,if you had the old type set up as on my Audi 80s you cant use them,but as you got the later set upoof bearing housing you might get to use them.....the the calipers Hope this idea helps cheers john |
Hi!
Anyone knows if the spindle carrier of the B4 tdi is the same as mine (B3)? If it was a B4 these brake upgrade would feet? I use these link to see the disc dimensions..and with the V6 disc i will have the same problem.. the overall is 56.2mm http://www.brakepartssuperstore.org....d116_Audi.html |
hi falcao, the calipers and carriers are g60 twin pots from a 1991 audi 90 quattro 20v, hope this helps with finding correct discs
#10 | |
The disc i have is the same as audi 90 quattro 20v. (276mm vented ) Anyone can show me the spindle carriers of a B4 TDI (with vented discs) or Coupé 2.3E 20v, or Audi 90 quattro 20v. I need to know the diferences between the spindle carriers of B4 and mine B3. Any info wellcome! |
| Advice On Brake Upgrade For UR | Steve | Suspension & Brakes | 1 | 02-01-10 10:09 PM |
| Brake upgrade for 84' type81, | itsa-dubthing | Suspension & Brakes | 5 | 31-12-09 10:18 PM |
| Brake problem - 200 turbo | 86audicoupe | Suspension & Brakes | 17 | 09-10-09 11:29 AM |
| CQ Brake upgrade? | Gaz | Suspension & Brakes | 5 | 27-09-09 04:34 PM |
| audi quattro brake problem | newt | Suspension & Brakes | 11 | 04-06-09 09:48 AM |
