Classic Audi » Technical » Mech/Tech » Engine » Servicing items
Old 15-06-09, 02:45 PM   #1
Default Servicing items
Will be servicing the car shortly as part of the top end rebuild. Need some reccomends for plugs, oil, HT leads etc for a WN engine. Parts and distributors reccomends welcome.
Also need a new cambelt
thanks in advance
Martyn
Old 15-06-09, 03:52 PM   #2
PeterB
You absolute shower!
PeterB's Avatar
thanks in advance
Martyn
Pete Reeve at quattroCorner should be able to sort you out with most of those Martyn.
For the HT leads I'd see if Magnecor make a set for your engine, the 7mm black ones that they do are fine and will look pretty o.e.
As for the oil, a good 10W-40 or 15w-40 should be spot on. Something like the semi-synthetic Synta Silver 10w-40 from VW.
Old 15-06-09, 05:57 PM   #3
gabriel.oconnell
gabriel.oconnell's Avatar
yes go to peter reeves of quattro corner for all you audi needs what a great guy
Old 15-06-09, 06:24 PM   #4
Yes either pete reeves or if you are really feeling brave take her to your local dealer and order the parts from there
Servicing the ol' UR stumack7 General Chat 0 25-02-09 01:15 AM
