Classic Audi » Community » General Chat » is THIS a WR block please?
Old 30-05-09, 09:14 PM   #11
JUST AS WELL.... took Archie to 3,000 rpm today
took the RallyRep to 6700rpm today.... Fookin Valves tap-dancing again... They love it!!!!
Old 30-05-09, 09:17 PM   #12
I must try harder then
as said to you when I spoke to you yesterday I am off to Knockhill tomorrow so looking forward to a day out with the old bastard
Old 31-05-09, 05:05 AM   #13
Do u want say there is no engine code on block? And what does it change anyway? WR wasn't audi's first 10vt engine so other 10vt engine must have identical block. Just because of code - "I have WR block [and not KG or whatever]"?
And about that "originality" and "switch back to 10vt in future" - yes, it will happen - because remaining ur's will be owned by collectionars and what do they need - originality, of course. Not moving exhibit doesn't need power at all And car, which is only somethimes driven to somewhere, doesn't need 100 extra hp's as well. The same way remaining A90q's will be turned back to KV's.
P.S. What's the reason for txt's about "invaluable blocks after some years" - because block is from WR or because brittish had scrapped almost all A200 10vt?
Old 31-05-09, 11:40 AM   #14
Cornholio
If you look at the 4th photo down, you'll see that the top of the dipstick tube points at an oblong pad, approx 4 inches long, right at the top of the block. Get some wet and dry and clean that up. The number that you will uncover will be the engine number, it will be of the format XX123456 (I think that it's 6 numeric, but might be 5). The 2 letters will tell you immediately what kind of engine it's from.
Also, a WR block will have oil squirters on it to cool the underside of the pistons.
If it's not a WR block, then it's worth what you'd get as scrap metal. As a bare block, even if WR, because it's damaged, it's not worth much more.
Cornholio is offline   Reply With Quote
Old 31-05-09, 01:42 PM   #15
Here you go Richard, taken especially for you!
Engine numbers on that shiny pad by the spanner on the left side of the block.
Old 31-05-09, 05:15 PM   #16
thanks 4V6 and Co.... learn something new daily about this block
point taken
.....oh yea so it does!!!!
bloody enigma code more like, what a stupid place to put it... who the f*** would think of looking there 30 years into the future?
Old 31-05-09, 05:32 PM   #17
Cornholio
point taken
Errrr? All 10v i5's have the engine number in this location......
Old 31-05-09, 05:40 PM   #18
ok ok!!
wonder if my 20V has a stamp hidden somewhere?
what about a 30v then... where would that be?
Old 31-05-09, 06:20 PM   #19
steveb
steveb's Avatar
They all have the engine number there but the lteers change WR/ MB/ RR /DS/ KV 00**** the letters being the type
[FONT]
'76 Leyland Princess 2200 HLS
'79 Scirocco storm
'84 WR
'89 coupe quattro
'01 A2 1.4 TDI SE
'14 A3 1.4 TFSI COD
[/color][/size][/font]
Old 31-05-09, 08:24 PM   #20
I think all old VAG engines have in the same place, only R4 block is shorter
Latest Ken Block Video Now out! Coxy General Chat 20 02-06-09 10:24 AM
Converting a AAT diesel block to turbo petrol? Kit Engine 1 16-03-09 09:48 PM
Audi 2.0 3a block/engine?? dubstar74 Parts Wanted 0 19-06-08 07:29 PM
