Classic Audi » Technical » Mech/Tech » Suspension & Brakes » Shock mounts needed for RS2
Old 17-05-09, 07:56 PM   #1
Default Shock mounts needed for RS2
I currently have H&R suspension on the RS2 and I need to change the shock mounts as they are past best and need replacing.
What are the best options and where can I get them from??
Old 17-05-09, 08:01 PM   #2
vag80
vag80's Avatar
are you on about the top mounts ? as there was some on fleabay
200k club member
87-b3 80
83-4000 2 door
Old 17-05-09, 08:02 PM   #3
SteveT63
SteveT63's Avatar
Hi Coxy. I assume you are talking top mounts?? If so...
Genuine Originals without any hestitation. Im not sure if they are the same as the S2, I would imagine they are.
I fitted original Greens to mine and they are by far the best. Pleeeese dont go down the solid top mount route, they are rubber for a reason.....to allow us to keep our teeth over the bumpy bits!!
T85 1985 90quattro I5 20vT
T81 1983 80 Sport Red
T81 1983 80 Sport Silver
Old 17-05-09, 08:02 PM   #4
yup!
have you a link?
Old 17-05-09, 08:03 PM   #5
The fact that you have H & R shocks / springs has no bearing on top mounts unless you have alloy ones......which you ain't if I remember. Give Pete Reeve a call, he'll sort you out with a set.
Old 17-05-09, 08:13 PM   #6
Coxy try Martin at www.unit20.org or unit20@btconnect.com
Old 17-05-09, 08:18 PM   #7
vag80
vag80's Avatar
http://cgi.ebay.co.uk/2-VAG-BLUE-STR...3A2%7C294%3A50
heres the link it don't list your but i think there all the same fittmet
200k club member
87-b3 80
83-4000 2 door
Old 17-05-09, 08:20 PM   #8
don't think they are the right ones tbh.
Old 17-05-09, 08:28 PM   #9
vag80
vag80's Avatar
have you got a pic of yours,the mounts are colour coded for differant grades i've fitted
green ones on my 80 with i think are quattro ones
200k club member
87-b3 80
83-4000 2 door
Old 17-05-09, 08:37 PM   #10
I haven't no as the car is with Rob at the moment.
[audi 100 C1] rear shock absorbers burny Parts Wanted 3 08-05-12 04:25 AM
Front shock help urgently needed! SteveCat Suspension & Brakes 2 04-07-09 09:42 PM
Type 89, 1989 2.2 5cyl rear shock needed lewiswilkinson Parts Wanted 8 17-05-09 02:30 PM
Audi Coupe GT Boge Sprint shock Absorbers tony Parts For Sale 1 30-03-09 04:42 PM
Audi 60,70, 72/75, 80 & 90 Front Shock Absorbers Drazic Parts For Sale 0 12-01-08 09:20 PM
