Classic Audi » Technical » Mech/Tech » Electrical problems » 90 20V SPORT mot failure help!
Old 15-05-09, 05:03 PM   #1
ian20v
ian20v's Avatar
Default 90 20V SPORT mot failure help!
My 90 20v Sport failed her mot,i fitted new rear discs,but have been told calliper needs replacing,a couple of brake hoses and a section of brake pipe too! Emissions were fine ,no ignition lights due to previous owners bodged ignition wiring job,he tried to chisel out the ignition lock,which he did but left the steering lock part in,can you imagine cornering then suddenly oops! steering lock on A load of wires have been cut right through,i guess these are from the sensors and should go somewhere butmaybe the back of the instrument panelThe garage has told me it will cost a lot to fix,and i would have to get an auto spark on the job,any suggestions or pointers most welcome.I do have a manual for the car ,perhaps a good place to start
Old 15-05-09, 06:22 PM   #2
Yep manual is a good place to start Do what you can yourself
Old 15-05-09, 07:05 PM   #3
I put one of mine in,to have clutch fitted and master brake cylinder.
While they were doing it,they severed a copper brake line.A few days after i finally got it back,i took the ex-wife for a driving lesson.It started raining so i put the wipers on(while the lights were on),next minute car full off smoke.
The prats had put the steering column pinch bolts in the wrong way,which split my wiring loom.It had shorted my lights and wipers.
From then on i try and do all the work myself.I can trust my and i,m alot cheaper.LOL.
Old 15-05-09, 09:15 PM   #4
ian20v
ian20v's Avatar
Yep you learn a lot too thanks
Old 15-05-09, 09:53 PM   #5
Ian... can Mike help you out with wiring looms?
Old 15-05-09, 10:03 PM   #6
ian20v
ian20v's Avatar
Is that Mike as in audibits2 or Mike as in Mikes2?
Old 15-05-09, 10:11 PM   #7
Mike audi bits 2
Old 15-05-09, 10:39 PM   #8
ian20v
ian20v's Avatar
Mike is more into coupe parts and s2 I've called and emailed him but heard nothing back yet.He's a busy chap.I'll be going down the manual route pick it up as you go along so to speak.THE GARAGE said it would cost more to repair than the car was worth[ BOLLOCKS!] Remember i paid £120 for the car its not about what the cars worth for me ,its the pleasure of getting her back on the road and polished up
Old 15-05-09, 10:41 PM   #9
good luck,if there is anything i can do to help......
Old 15-05-09, 10:50 PM   #10
ian20v
ian20v's Avatar
Its going to be a weekend working on her,i've got a few days to get her back for the mot or pay another fee.Thanks for your offer of help,HMMMMM hows about another 90!Is'nt she lovelly!
engine MOT failure.... quattrokid General Chat 17 21-05-09 08:24 PM
Headgasket failure seal.... Puglife General Chat 1 07-03-09 03:26 PM
Help! Cambelt failure! Lankytim Engine 25 17-09-08 09:34 PM
