Classic Audi » Community » General Chat » C3 binding brakes
Old 04-06-23, 11:47 AM   #1
Ringmaster
Ringmaster's Avatar
Default C3 binding brakes
Hello folks,
Was happily tootling along in my C3 yesterday. Braked at T junction and heard a loud click come from the area behind the instrument cluster. Afterwards the car seemed to be sluggish. Speed didn't relate to engine revs. The brake pedal felt very firm at times. Carried on home and heard another click. Car surged forward as though liberated from some invisible force. Braked again and the car became sluggish. Splashed some water over all 4 wheels and they were steaming hot.
Me thinks I have a faulty brake booster rather than a faulty master cylinder.
Opinions, please....
Old 23-05-24, 08:56 AM   #2
Ringmaster
Ringmaster's Avatar
Turns out my brake master cylinder was corroding within. Where it meets the brake booster was full of aluminium powder which must have been clogging the mechanism and causing the binding intermittently.
A good clean and new master cylinder solved issue!
Old 23-05-24, 10:26 AM   #3
ovalking
Glad you found a problem and hope the solution is long lasting.
Were there any external clues?
Mine seems to be working fine. But I'm changing some flexi hoses at the moment, and brakes are on my mind...
ovalking is offline   Reply With Quote
Old 23-05-24, 11:13 AM   #4
Ringmaster
Ringmaster's Avatar
There were no external clues. Looking back, as all 4 wheels were affected, we should have immediately looked at the master cylinder rather than wasting time flushing the brake fluid.
There is a gasket between the M/cylinder and brake booster. That had perished causing aluminium to contact the steel of the booster, which probably triggered the corrosion.
