Classic Audi » Technical » Mech/Tech » Electrical problems » Audi A8 electrical fixes
Old 12-12-23, 07:02 PM   #11
4WDrifter
I’ve always fancied these and this one looks like it has half the Amazon rain forest veneered inside it. My money is on the brake pedal switch mine used to stick all the time. Hope you get the niggles sorted. Health to enjoy!
4WDrifter is offline   Reply With Quote
Old 15-12-23, 12:25 AM   #12
theschmallfella
theschmallfella's Avatar
Originally Posted by Sandro View Post
On my V8 (which uses same cruise control system) - cruise control was kind of "stuck". I pressed hundred times cruise control button and it started to work. Very often on these the problem is in the switch itself. It looses the contact and no more cruise control.
For the sunroof - same thing. There is relay under the button cover. Take it off, take off the relay, check it, check connectors, check if there is power coming to it. These are pretty simple there.
Faulty headlamp washers might be related to stuck motor in washer bottle. Or just not enough fluid On late V8's headlamp washer is placed higher up so if fluid gets low, it just does not get fluid
These are all very good suggestions Sandro, thanks very much! She's gone into hiding for the rest of the winter so it'll be a while before I get back to it again.
