Classic Audi » Technical » Mech/Tech » Engine » Could it be the Cold Start Valve?
Old 12-09-23, 10:59 AM   #41
84CoupeGT
84CoupeGT's Avatar
Good point, I was assuming it has the traditional servo. It seems some 1987 C3s have this set up, but 7zap isn't clear which ones. Item 2 in the diagram..
Old 12-09-23, 11:45 AM   #42
Ringmaster
Ringmaster's Avatar
Originally Posted by tractor Dave View Post
Not up on C3 model but have you got a traditional servo or a hydraulic brake booster and bomb?
I've got the hydraulic brake booster and bomb....
See https://webautocats.com/en-gb/etka/audi/a100/73/085100/
Old 12-09-23, 01:55 PM   #43
tractor Dave
In that case could be your brake booster is faulty. You don't have a vac line to servo on that set up. Faulty booster can cause all sorts of strange issues. It has no impact on engine running other than drawing power from you tandem pump.
Old 12-09-23, 06:05 PM   #44
Ringmaster
Ringmaster's Avatar
Thanks Dave. I'm worn out with it. Taking it to my garage tomorrow.. Will advise...
Old 12-09-23, 08:48 PM   #45
tractor Dave
Don't lose heart. It's bound to be something simple. Are you near West Wales?
I can take a look for you but I'm no C3 expert.
Old 12-09-23, 09:21 PM   #46
Ringmaster
Ringmaster's Avatar
Thanks for the offer Dave but I'm over in Sussex..
Old 13-09-23, 06:26 AM   #47
tractor Dave
Sorry I can't help then. You just need the right garage/person to look at it. Old school garage who understand old school cars. Not somewhere who expect to plug it into a computer!
Old 13-09-23, 09:10 AM   #48
ovalking
Vacuum servo on 4-cyl models only.
ovalking is offline   Reply With Quote
Old 16-09-23, 01:13 PM   #49
ovalking
Originally Posted by Ringmaster View Post
Had the emissions checked at my local MOT centre and it was running very lean. CO showed as 0.4. They set it to 3.3 and engine seemed a little smoother. However I needed to see how it did from a cold start.
My last CO test reading was 0.368.
3.3 seems way too close to the max of 3.5.
Old 16-09-23, 07:47 PM   #50
Ringmaster
Ringmaster's Avatar
Yes, I think so too. It may be the cause of why the engine revs increase for no reason when idling.
Will have to sort that. My MOT is due next month and the MOT chap may kindly adjust it for me.
I considered turning the adjustment screw a little to the left myself, but probably best not to without knowing the exhaust emissions.
Surprised .368 isn't causing you trouble in view of mine had been at 0.4.
