Classic Audi » Technical » Mech/Tech » Suspension & Brakes » Top mount tool size for b2 CQ ?
Old 27-07-22, 05:51 AM   #1
Gaz
Gaz's Avatar
Question Top mount tool size for b2 CQ ?
Can anybody tell me what size top mount tool I need for b2 Coupe Quattro?
Can't find the one I did have and car is at the garage.
It's the two pronged hollow nut thing I'm after.
Old 27-07-22, 07:18 AM   #2
tractor Dave
I'm 99% sure they are all the same.
Old 27-07-22, 08:47 AM   #3
BackintheFold
BackintheFold's Avatar
Agreed.
Also, I've only ever used a big screwdriver. Last one I did the previous mechanic did it up with their eyelids judging by how loose it was...
2006 A3 (daily drive)
1987 MB ur
Old 27-07-22, 02:07 PM   #4
84CoupeGT
84CoupeGT's Avatar
This is the same as the one I got for my Coupe GT...
https://www.ebay.co.uk/itm/403618110...mis&media=COPY
Old 27-07-22, 06:37 PM   #5
Gaz
Gaz's Avatar
Cheers everyone!
Second question, I might now need new nuts as they have been damaged.
Old 27-07-22, 07:19 PM   #6
84CoupeGT
84CoupeGT's Avatar
Plenty on eBay, part number is 811412365
Old 27-07-22, 07:40 PM   #7
Groundhog
Originally Posted by BackintheFold View Post
Agreed.
Unlikely, what happens, if one is not careful, is when the nylock nut is screwed down the strut centre turns but the gland nut stays gripped to the mount thus unscrewing it.
It is vital that when fitted the nyloc nut that the damper piston is held from turning with a hex head key while the nut is tightened.
A loose or backed off gland nuts generally results in a ‘chattering’ from the suspension.
Groundhog is offline   Reply With Quote
Old 28-07-22, 12:55 AM   #8
K Simmonds
K Simmonds's Avatar
I'm not super familiar with B2 front top mounts, However I can tell you that tool in you first post is used for disassembling strut's once off the car.
Any garage worth their salt could knock up on of those tools from an old socket in ten minutes, that what I use.
Still have my RS2 tuck up safe, also a 1992 C4 2.8 Avant quattro and a B3 quattro Saloon G60 conversion in progress.
