Members: 43,027 | Total Threads: 40,085 | Total Posts: 471,031 Currently Active Users: 616 (2 members and 614 guests) Welcome to our newest member, robert23Nouby |
Folks,
Tried to change my fuel filter and went to undo the nut that holds the clamp that holds the canister. Looks like the nut merely goes on to a threaded bolt that was immersed in rubber and stuck to the body. That rubber has perished and the clamp has broken away from the car's body. So now I can't undo the bolt (it just spins) and fuel filter is just hanging there by the fuel lines. The bonnet strut now clashes with it if I open/close the bonnet. I will try hacksawing through the threaded bolt to free the clamp, but any suggestions on what to replace the set up with? I assume I will need to drill into the bodywork with some sort of self tapping screw/bolt... ![]() Last edited by Ringmaster; 02-04-22 at 05:25 PM. |
It's a radiator mount.
803 121 275 A The stud on the mount goes through the clip and a nut holds it all in place. I'm guessing the other half stud of the mount goes through a hole in the body and is held in the strut tower by another nut.
My clamp has broken away too. I don't need to change the filter, but there will be some repetitive stress on the fuel pipes that should be avoided.
Super glue was ineffective. Going to try a blob of adhesive sealant next. Will wait until a few sealant-type jobs build up! |
#4 | |
Yes, the other end of the radiator mount goes into the wheel arch.
Can't undo the bolt as it just spins. I have the clear Gorilla glue. Will try sticking a nut on the sheared off end. Hopefully it will be strong enough. Last edited by Ringmaster; 09-04-22 at 04:57 PM. |
