Members: 43,060 | Total Threads: 40,086 | Total Posts: 471,048 Currently Active Users: 3677 (3 members and 3674 guests) Welcome to our newest member, Charleshiews |
#11 |
Simple test for N75 ‘triggering’ for an AAN/ABY is disconnect it electronically. If it makes no difference then that doesn’t (necessarily) mean to say the N75 (in itself) is broken, it means the ECU isn’t seeing the right signals (conditions) to trigger N75 and that might be boost leakage or, more likely, the MFTS (Multi function temperature switch) etc.
#12 | |
I see "3mm" and "5mm" cited, as well as 5/32 inch. Is that internal or external diameter? And what is the right size for the B2? I'm guessing 12 feet/4 meters would be enough. I'll take a look at mine next week if no-one knows off the top of their head! This is what I'm thinking is correct-4m at 3.2mm inside and 10mm outside diameter. https://www.ebay.co.uk/itm/113923748...oAAOSw85Jexp3q Cheers
2014 S3 (daily drive) 1987 MB ur Last edited by BackintheFold; 05-08-21 at 09:22 AM. |
