Members: 43,064 | Total Threads: 40,086 | Total Posts: 471,052 Currently Active Users: 6534 (2 members and 6532 guests) Welcome to our newest member, JeffreyVak |
#11 | |
Incidentally, the screw I removed has a vertical crack in the side of the cap head. Not a failure mode I've seen before. Have you ever seen a cracked bearing support housing as a result of loose/missing screws? If the screw can crack I guess the bearing housing can too. |
#12 |
Image of cracked screw (90Q rear output shaft bearing housing)
#13 |
I take it there's no room for a grip socket in the space available ?
These have saved my bacon a few times on rounded cap bolts
#14 |
Sorry to hear it wasn’t successful. It would seem someone has been there before you and failed. The split bolt, I suspect, is as a result of a previous removal, I’m guessing someone hammered something to big in there, it had the desired effect in that I would imagine they removed it but then failed on the last bolt which is why the splined socket trick won’t work. I would do as you said replace the two and keep your fingers crossed.
I have never known a housing to split. |
#15 |
Have you got a mig welder?
Weld a small bolt in there. Don't forget to remove you ecu's first. |
#16 |
Unfortunately, it's about 10mm down inside a counter-bore - so pretty inaccessible. Thanks for the suggestion though. I've never used a grip socket - sounds like it worth having in the tool kit.
#17 |
#18 | |
#19 | |
#20 |
Thanks for the link John. Much appreciated.
| Tags |
| 90q, gearbox, rear output shaft, seal |
