Classic Audi » Classifieds section » Parts Wanted » Rubber door trim/strip
Old 30-03-09, 09:41 PM   #1
Sie!
Default Rubber door trim/strip
Hi all,
Another piece im after, I want a replacement rubber door strip for my 1985 Audi 80 - you all know the one by now!
Its the rubber trim that runs the length of the door, and its for the passenger side rear.
Many thanks in advance,
Sie!
Old 31-03-09, 08:17 PM   #2
BigT80
Hi Sie, I've got one of those, but not sure on the condition; will have to check at the weekend, but if someone else offers one, go for it, in case my spare is not perfect. Cheers.
BigT80 is offline   Reply With Quote
Old 31-03-09, 08:39 PM   #3
from here
http://www.audivwparts.co.uk/www.aud...earch=&sought=
Old 31-03-09, 09:54 PM   #4
Sie!
Hi Geln!
Thanks once again for that, appreciated as always!
Micky, again, thanks for that tip, but the ones on mine are slightly different.
Sie!
Old 06-04-09, 09:39 AM   #5
BigT80
Originally Posted by Simon A. Baskerville View Post
Hi Geln!
Sie!
Hi Sie, I found the one I have. It is in good condition, but came off of my late pre-facelift Sport. I've compared it to the one on my early 80q & they are different, but then it is slightly different (but close) to that of my facelift Sport, so I hope it might do the job. I have taken a pic & attached) it to try and help. Why did they keep changing them!
Cheers. G
Old 08-04-09, 02:33 PM   #6
Sie!
Hello Mr G!
Hows things?
Its not actually that piece im looking for - just read my ititial post and it is a little vague, so my apologies for that.
The actual piece im looking for is this one here:-
As ever mate, thanks for your help!
Sie!
Old 08-04-09, 08:42 PM   #7
BigT80
Hi Sie!
Ah; the dreaded outside trim. early ones were much more resiliant, these later ones rusted from the inside out. Removing them is difficult, best as a cheese-wire job, so most get bent & as soon as that happens they're useless.
Anyway, all of that you probably know & it doesn't help much because I've not got one detached , but I have just remembered I've got a set of doors that have got that type on. I'll have a look and post a pic in a few days to see if it is any good? . Cheers. G
Old 13-04-09, 02:36 PM   #8
BigT80
Hello Sie, Well I found one. It's reasonable, but is plain black, but I think yours may have the 'chrome' insert in the top part? I've not bothered to photo yet as if that's the case this one aint no good. Also where the bottom of the two metal strips runs through it, if you look very carefully, you can see it's starting to bubble slightly under the plastic; so may be no better than yours. Cheers. G.
Old 13-04-09, 06:07 PM   #9
dandan
big gimping
dandan's Avatar
don't shout at me but ive just removed all of my rubbing strips and thrown them away.....if id of known you could of had all of them
dandan is offline   Reply With Quote
Old 13-04-09, 06:11 PM   #10
Davey101
Hi guys,
Sorry to threadjack, but I'm looking for the same piece for the driver's (front) door.
Davey101 is offline   Reply With Quote
b3 90 quattro front drivers door/bump strip sam Parts Wanted 0 15-06-09 08:24 PM
Bonnet Chrome Trim & Bumper rubber Wanted - 100 Coupe MartyP Parts Wanted 2 18-05-09 01:11 PM
Rubber door strips for 90q WANTED ian20v Parts Wanted 0 26-03-09 11:02 PM
Door Strip Adheasive Sie! Bodywork, glass & exterior fitments 2 10-02-09 06:36 PM
Drivers door bump strip a25c Parts Wanted 2 28-09-08 11:58 PM
